Old 06-22-2004, 10:51 PM
Breck SVX
If you read the TSB that shouldn't be possible, the screws that make that noise are under where the airbag is.....or would be. The others are about 2 inches or so behind where the dash meets the windshield. When I took it appart I noticed that someone had already covered the locating pins with felt. This obviously did not solve the problem as my dash still creaked. If it works though; godspeed....I think i'm just bitter because I didn't try that first
-Alex
p.s. if anyone trys this, be careful to remove the hazard/signal relay before pulling the dash.
Old 07-04-2004, 11:19 PM
Breck SVX
back in and lookin' fine...now I have to wait until winter to see if it did anything...on a side note, sprayed silicone on all the door seals and those pieces of rubber that the windows slide against towards the b-pillar, no more squeaking. As a result of this whole experience I've come to feel the same way about silicone as I do about duct tape, awe and amazement.
-Alex
