Old 03-24-2004, 12:16 PM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
Question My windows, power seat, and moon roof wont work.
The day I strarted the 5spd swap, the driver seat wondent move(that was annoying to take out), now that i am done with the swap The driver seat, the windows, and the moon roof wont move. I tried changing the fuse (SPF1) nothing happened. Any ideas? Thanks
Old 03-24-2004, 01:20 PM
lee lee is offline
there's also fuse 15 under the dash to consider, the window circuit breaker, and the ground under the driver's seat (for all three systems).
Old 03-24-2004, 05:47 PM
svxsubaru1's Avatar
Were is the ground and the circut breaker? I am going to change fuse 15.
Old 03-24-2004, 07:28 PM
lee lee is offline
sorry, never had to look, just going by the info I have from Alldata.
Old 03-24-2004, 10:37 PM
Did you ever find fuse 15, and if you did, where did you find it?
Old 03-25-2004, 09:43 AM
svxsubaru1's Avatar
Going to check fuse 15 today.
Old 03-25-2004, 04:11 PM
svxsubaru1's Avatar
How do you find fuse 15, what is it listed as?
Old 03-25-2004, 06:17 PM
lee lee is offline
the fuses in the interior are numbered 1 through 21.
do you have the interior fuse box cover? To help oreintaye you, on my 92 model LS-L Fuse #1 is labeled Back/Turn, # 7 is R-Def, fuse #8 is labeled SRS Air Bag, #14 is EGI Unit/AT Unit, #15 is labeled Meter SRS Lamp, and finally #21 is Heater. See attached, the numbering is from the point of view of looking at the box, top left fuse is #1, others follow as in the diagram.
Also see second page for how the electrical feed is used - two fuses for windows, etc.
Old 03-26-2004, 11:37 PM
svxsubaru1's Avatar
Checked and changed it and it dident solve it. Looked like the fuse had a good conection to no rust.
Old 03-27-2004, 06:07 AM
lee lee is offline
my advice is to check the grounds and power continuity.
you just need to go along the circuits and with a VOM, check for zero resistance to ground and 12-14 volts where it's supposed to be
Old 03-27-2004, 03:46 PM
svxsubaru1's Avatar
Do you have any idea were the grounds are?
Old 03-27-2004, 04:54 PM
lee lee is offline
never had to look, but under the driver's seat somewhere according to the manual, and several posts I've read on here. might try a search of two & see if anyone ever described the place - but I don't remember it if they did - of course my memory is (always has been) suspect.
Display Modes
