Old 03-21-2004, 08:43 PM
tracedog67
suggested exhaust system
I have some rusting and leaking in the exhaust pipe after the cat convertor where it bolts into the Y pipe. The metal flanges of thepipe are delaminating at the donut gasket and the system is much louder than it should be, it sort of sounds like one of these rice burners nowadays with the big 4" mufflers out the back. What new exhaust would one suggest or can I just replace the section from the manifold to the Y pipe with the cat included?
AND what is best price and place to get it?
thanks fellers
Tdog
Old 03-21-2004, 11:59 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
you live in Cinn ?
cool, my sister lives there, she just got her 1st
94 Laguna Blue Svx. Going to be putting one of our
systems on there this summer.
For more info, check out our site, maybe we can help
thanks
Dayle
(links below)
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 03-22-2004, 09:10 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
same exact thing happened to me
You're right, it sounds horrible but I got it fixed. I found a local exhaust place and what we did was to cut out all 3 of the stock subaru cats and replaced the 2 small cats with high flow cats from a mustang and then they welded together a new Y fitting with a piece of flexible pipe.
When it was all said and done not only did it fix my exhaust problem but it increased the flow of my exhaust a lot! My SVX runs ten times better now.
The shop was able to do the entire job for $300. I would highly recommend it. If you want more specifics feel free to IM me and I'll tell you more and i think i have some pics that i could show you as well of the job. Let me know.
~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 03-22-2004, 09:56 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Yeah, what Ray said
Dayle has some good deals on high flow cats and resonators - go with the 2.5" size!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-22-2004, 10:58 AM
mbtoloczko's Avatar
sans SVX
Originally posted by SVXRide
-Bill
And based on elninoalex's many exhaust system variants, true duals are not as good as a single pipe.
Mychailo
Visit my locker
