Old 01-04-2004, 02:18 PM
atchernyshev
Lightbulb EG33 service manual (repair manual)
Dear Guru,
Please help for find service manual for EG33 .. very needed for start new project ..
P.S. may be you know online shop ..
thank you .....
Old 01-04-2004, 05:23 PM
I'm not Guru, but you can get a Factory Service Manual here. Good Luck on your project.
Old 01-07-2004, 01:19 PM
Re: EG33 service manual (repair manual)
Originally posted by atchernyshev
Dear Guru,
thank you .....
Do you need a complete SVX set, or just the manual for the engine??
And as it's your first post, welcome.
I expect it is not the weather in Moscow for s ? Plenty of snow to check out the four-wheel-drive maybe?
Old 01-07-2004, 01:44 PM
Mr. Pockets's Avatar
Moderator
Moscow, huh? Cool. Man, post some pictures. I hope you can find a factory service manual set, but in the meantime what's the problem you're having? We can probably help.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-07-2004, 04:40 PM
oab_au oab_au is offline
Dear Guru,
thank you .....
Hi, The model that you have is a bit different to the US version, it is probable the same as the European version. You should try to get a set of manuals for your model, sent to you from Japan. 6 volumes, $200,Australian.
If you have a problem with a particular section, I can scan that page for you.
One Arm Bloke.
Tell it like it is!
Old 01-08-2004, 10:06 AM
atchernyshev
Than you for answer ... engine ... eg33
about weather.. You are right..
thank you for help ..
Andrew
Old 01-08-2004, 10:10 AM
atchernyshev
What picture interest..?
Problem ... a try to understand about mounting eg33 in to Legacy
Thank you for any info.
Andrew
Old 01-08-2004, 10:16 AM
atchernyshev
Re: Re: EG33 service manual (repair manual)
Thank you for answer ...
You know web site for order ? if know please send me URL .. $200 Australian .. is OK ..
I at all would not dare(be solved) to ask you scan.
Because I am interested by all engine related parts..
Thank you ..
Andrew
Old 01-08-2004, 10:33 AM
Moderator
Andrew
Ah - I just assumed that you had a problem with an EG33 in an SVX. If you're mounting an EG33 into a Legacy, then I guess that's what I want to see pictures of.
The engine should bolt right up to the transmission. If you're attempting such a thing, I doubt you're intimidated by the other peripheral bits like wiring or air conditioning. The problem, I would suspect, is space.
2005 Outback
END OF LINE
Old 01-08-2004, 10:41 AM
atchernyshev
Yes it is valid, the documentation is necessary for understanding for me, it is possible eg33 to establish in a motor compartment legacy whether or not... Wiring and airconditioning it is decided(solved) problems..
