Old 11-12-2003, 03:01 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
CD Players
Ok, so my dvd player in my room plays dvds (obviously), reg. music cds, cd-r's, cd-rw's, and mp3 cd's. but lately it has been tempermental as to which cd-r's it will play. Alot of my cd's are burned and its really annoying, it has trouble reading them or something im not sure. any ideas? this hasnt happened since ive owned it around xmas time. im confused!
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 11-12-2003, 03:38 PM
Darksied-X's Avatar
Darksied-X Darksied-X is offline
Recluse
Send a message via MSN to Darksied-X Send a message via Yahoo to Darksied-X
The most likely culprit is simply the brand of disk. I've used two different types of disks recently, Phillips and Memorex. The Phillips play great in anything. The Memorex, however, either won't play or sound like crap in the same players. If it's doing it to disks that used to play fine, it's probably either the disks are scratched, or the player is going to crap. CD-R's are much more sensitive to scratches than regular CD's. If the player is a cheapo, like Apex, then it's not suprising that it's doing this, and will probably only get worse.
-Evil Jeff
'03 WRX Wagon, World Rally Blue
'94 SVX LSi, Barcelona Red
'89 XT6 4WD, Grey & Rust
(and legally, an '01 Outback VDC skankmobile)
Old 11-12-2003, 03:43 PM
petesvx2's Avatar
you know what i think you're right with the brand of cd's, because i was using Sony's that worked really great, then switched to some things i found in my closet....its interesting though because they all play in my car and in my mom's car too....*shrug* oh well, i guess i just cant listen to certain ones
thanks!
Kenwood KDC-MPV619
Wedgie Cupholder
Old 11-12-2003, 03:59 PM
Darksied-X's Avatar
Recluse
Another possibility I just thought of. I don't know if this is the case with all burners, but when I used music type CD-R's to burn a music disk in my computer's burner, it doesn't play right. It seems those are specifically for stereo system CD recorders, and you need to use data CD in a computer burner, regardless of what your putting on them.
-Evil Jeff
Old 11-12-2003, 04:18 PM
Mr. Pockets's Avatar
Moderator
As far as I know, there is no such thing as a CD-R which is specifically made for music or data. They may be advertised as such, but there's no real difference. Why? Because the stuff being recorded (whether Word files or music) is just 1s and 0s. Format is pretty much irrelevant. I would believe it if Memorex, for a random example, packaged two CD-R types and labeled one 'data' and one 'music' and made the 'music' discs more reflective so they'd work in more CD players. But reflectivity would be the only difference.
As for reflectivity, it's likely the source of the problem you're experiencing, Pete. CD-Rs are not as reflective as stamped CDs, so a CD which works in one player may not work in another. Similarly, one brand may work in a given player, but not another brand.
If you're finding that CDs which used to work in your CD player no longer do, it could be a few things. First it might be that your lens just needs to be cleaned. Second, your disc may be scratched. And third, the disc might just be old. They lose their reflectivity over time, especially if exposed to heat or sunlight.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-13-2003, 04:42 AM
KennEls KennEls is offline
CD-r
I agree with what you are saying,
If the discs have been working and now don't it would suggest that either your lens needs a clean or that your CD's could use one, also CD-r is not as stable as normal CD's.
I have also noted that some DVD players are touchy about playing anything that has been recorded at high speed, much more so than dedicated CD players, could explain why they play in the car and not your DVD player
Regards
KennEls
Old 11-13-2003, 10:41 AM
Chicane Chicane is offline
Anti-BS Vigilante
Send a message via ICQ to Chicane Send a message via AIM to Chicane
Sometimes there are. When companies first started to make home stereo CD recorders, some of them needed 'special' music CDs that were preformatted to be audio CDs. All the burner did was just add the music, somehow. The reasont they did this was so they could charge people an arm and a leg for SPECIAL CDs.
But yeah, you're mostly correct.
- Rob
Old 11-13-2003, 10:49 AM
Moderator
- Rob
I'll have to look into it, but I can almost guarantee that, even with early CD recording decks, there was no 'preformatting' of discs. I would believe it if the manufacturers tested the decks and found that they worked best with certain types of CD-Rs, so they sold those CD-Rs as their own brand. But that's about it, as far as I understand it.
2005 Outback
END OF LINE
Old 11-13-2003, 11:59 AM
Bobb Bobb is offline
CD-R
Hi everyone, On a recent "Screen Savers" show on Tech TV, they reported that burnable CD-Rs etc. were becoming unplayable in as little as two years after burning. Something to think about. Take care, BOBB
Old 11-13-2003, 05:29 PM
Earthworm's Avatar
Meow!
I've been burning CD's for over 6.5 years and all my original CD's are still fine.
Old 11-15-2003, 11:00 PM
petesvx2's Avatar
well my problem is intermittent, certain times they play certain times they dont....grrrr
Kenwood KDC-MPV619
Wedgie Cupholder
Old 11-16-2003, 06:22 AM
squiggy
i have found that the slower I burn the CD the better it plays..It resists the skipping as compared to 16x or 32x...it takes longer but that seems to work 4 me
Squiggy
