Old 08-20-2003, 06:13 PM
Marissa
rear end
ah oh.......looks like my rear end is going.
Any suggestions? Is it something my husband can do? He wants to know if it is possible to pull the U-joint and tighten the pinion gear. I heard that the U-joints have to be cut off that they are integrated with the drive line....is this true? AAACCCKKKK!!!!
Old 08-21-2003, 09:21 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Can you give us the symptoms? It may be a bushing rather than a diff problem.
Here is a good exploded view of the diff:
http://www.subaruparts.com/diag/?mod...category=195-A
The flange plate is torqued to the pinion shaft at 125-146 ft lbs so I severely doubt it has loosened up.
As for the driveshaft, it unbolts from the diff via four 12mm bolts and nuts. The driveshaft is not serviceable, but you can take it in and have new yokes welded on that accept replaceable U-joints. My last one cost $239 to be converted to replaceable U joints.
Hope this helps.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 08-21-2003, 09:46 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Re: rear end
It is very simple to swap out the rear diff. Let us know if it comes to that.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
