Old 02-11-2003, 01:28 PM
JLittell
Door Panel Bubbles
Anyone have a few mysterious bubbles in the vinyl behind their door panels? I noticed that I have a few on the inside of the right door panel above the arm rest. What is causing this? Water? I have no apparent leaks anywhere...Ideas?
Old 02-12-2003, 10:06 AM
svx_commuter's Avatar
I do not have them but I would like to know.
Are they soft if you touch them and compress to where they should be? You know can you push the bubble down and looks okay then?
Old 02-12-2003, 11:20 AM
JLittell
As if the bubbles are in the foam and not the outer vinyl covering. I push them back in and they will pop out a bit. So pushing on them won't fix it. ?? Really strange... I wonder if any water got in there and expanded the foam when it dried?
Old 02-12-2003, 01:37 PM
I was thinking it may be possible to put some glue under the vinyl but if it's deeper into the foam I don't know. Maybe with a needle or something.
Old 06-22-2003, 09:05 AM
JLittell
Again...Does anyone have these bubbles beneath their door vinyl???
http://www.subaru-svx.net/photos/fil...ttell/9733.JPG
Old 06-22-2003, 09:27 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
I got one in the rear pasenger side panel.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 06-22-2003, 01:20 PM
I was talking to a friend of mine about this and he said that it is the glue that let go from the pannel in those places. You could reattach it with more glue, but the only way to do it is from the back side of the pannel. He has a jeep that has had that happen to it as well.
Old 06-23-2003, 08:52 AM
JLittell
Its nearly impossible to pull up the door vinyl (I wouldn't recommend it!) Getting to these spots from the back would be quite cumbersome. I wonder if you could make inject some glue through a needle into this spot??
Old 06-23-2003, 09:36 AM
I would hate to make it look worse than what it does not. I wonder if a heat gun would warm the material and allow the glue to stick again.
Old 06-23-2003, 10:16 AM
JLittell
Good idea. I'll try it!
Old 06-23-2003, 11:20 AM
Invisible avatar
Wink
If the foam backing is anything like the stuff used by Mopar for their late '80s headliners, you be in a world 'o hurt. The stuff turns to powder & anything injected just won't stick. I suggest covering with aluminum siding.
Ron (tin man).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
