Old 04-01-2003, 02:23 PM
harvey
Question Security System Problem
Hi guys, it’s good to have a place to go with these frustrating situations.
I need to know where the horn relay is on my 94 SVX L.
Here’s the story: I installed a new SOA security system and when I reconnected the battery the horn sounded continuously. This was with the key/ignition off . The dash security system switch had no effect so I disconnected the battery and removed the module.
A previous owner had installed an aftermarket alarm system which was removed before I bought the car. Several wires have been tapped and taped including all four wires to the ignition switch, the brake light switch, interior lights, parking lights, and lock switch. I fixed a short at the lock switch but it seems there must be another short in the horn circuit. So I’m searching for the horn relay to find another tapped wired that is probably shorted.
All suggestions are appreciated. I hate laying out bucks for a factory system and not having it work.
Thanks
Old 04-01-2003, 04:53 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
The horn realy should be in a cluster beside the kick panel fuse box.
Randy Johnson
Mike Davis -- at Reading VI
