that would be on the bottom right if your under the car looking up at it...also known as the passenger side guess that would of been easier to say...
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
I tried to change the seals but it was impossible to take out the bolts from the cams ( to remove the timmimng wheels).
How did you kept the cams in place to remove the bolt? |
That's what the strap wrench is for. I got a set from Sears. The bolts are on very tight, so you'll probably need some help.
KuoH Quote:
