Old 06-08-2003, 04:31 PM
ChronicSVX
Angry Spark plugs
Okay, I need to know how the #uck you remove the Spark plug that is all the way in the back on the drivers side of the engine bank. I've removed and replaced the other 5 but I cant get the 6th one.PPPLLEEEAAASSEE HHHEEEELLLLPPP!!!!!!!!!!!!!!! I'm going #ucking nuts!
Old 06-08-2003, 05:56 PM
ChronicSVX
BTW I'll make one more attempt tomarrow when I actually remove my LF tire and just use that tiny #ucking panal but the previous owner put some #uCkinG BONDO over it!!. arrgh!! damn moron! but It should'nt be too break, I have enough sharp objects to get me through. Still a sparkpark change should'nt be this hard.
BWTM, It's Real fun to drive with just 5 fresh plugs,
does anyone know what its like with 6?
Old 06-08-2003, 06:34 PM
awdsvx awdsvx is offline
Spark Plug removal
I just replaced my spark plugs 2 weeks ago. You better have alot of patientence. Brains not brauns. I put in Bosch Platinum Plus 4, they rock in the SVX. But here is the link I used. Good luck.
www.ryanmacdonald.com
Old 06-08-2003, 07:25 PM
lee lee is offline
I think you need to investigate a little "wheel like thing" that fits up to a 3/8" drive extension. I wish I knew it's name, I think I got mine at sears. It's basically a square 3/8" drive fitting connected with a knurled circle about 1.5" in diameter so you can use your fingers to turn a socket.
here's the process I used: put a 3" extension on the spark plug socket. put this on the spark plug. get a rachet onto the extension and use it to free up the plug. take rachet off extension. Use small "wheel" thing to get plug all the way un-threaded. Had to follow this procedure because rachet couldn't get plug out without contacting body before plug was fully loose.
reverse process to install. my engine was overnight cold during all this of course.
Old 06-08-2003, 08:41 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
I got it out with a standard ratchet and a 3" extension.
I did, however, had to let the ratchet sit "loosely" on the extension (i.e. not snapped in) so that I could remove the ratchet and using the hand to turn the extension. Otherwise, the ratchet would have been pinched against the frame of the car.
VK
Old 06-09-2003, 08:29 AM
Mr. Pockets's Avatar
Moderator
I'm pretty sure that I just used a 3" extension, as well. I did not need the little access hole through the wheel well.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-09-2003, 09:03 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
It is called a palm ratchet. They rock. I have the Snap On fine tooth units.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 06-09-2003, 04:21 PM
Chicane Chicane is offline
Anti-BS Vigilante
Send a message via ICQ to Chicane Send a message via AIM to Chicane
Chiiiiilll Win-stonn
Old 06-09-2003, 05:07 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Maybe he was referring to a spinner, a flat disc with a square hole in the center and a knurled edge, that just clicks in between the extension and the ratchet?
Old 06-10-2003, 06:08 PM
ChronicSVX
Talking
ah-HA finally did it last night!! now I've got all 6 bosche platinum 4's in!
Old 06-10-2003, 06:41 PM
Gap???
Did you gap your plus 4's???? Doh!!!!!!!!!!..................................... ...........Just a joke, you don't gap them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Bosch tells you they are factory set already and do not need gapping! Good Job!
Old 06-10-2003, 11:59 PM
ChronicSVX
Why would I gap them, I already knew that@!
