TCM Crack
Anyone still working on this? When are we gonna see someone dump one of these and make a custom one?
I'd pay alot for one with Revised shift patterns, and one that is more willing to downshift, sorta like the new 4EATs do, and for god sake AT OIL TEMP light should come on at like 225 pan temp.... not 304.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Re: TCM Crack
...wait are you saying that you want to be warned before your ATF ignites
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
Re: TCM Crack
I am working on it whenever I get any spare time.
I have dumped it to a file and disassembled the program. So far I have successfully made minor program customisations to two TCUs. It's a hobby for me, not a money making venture. Whatever I find out will be documented here and on my website. In time I will be able to make those changes for you for the price of a EEPROM chip and a beer. I absolutely agree that the AT OIL TEMP light should be triggered at a much lower temperature. I assume you are alreay using Nomake's power mode switch mod?
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
Re: TCM Crack
Re: TCM Crack
So I've been away but i wanted to check back up on this. I would really like to have a new ecu program, not for "performance" per se but more for better driveability. I find the stock TCU kinda stubborn, like it really would rather not downshift if it doesn't have to.
Re: TCM Crack
Have you tried Nomake's power mode switch mod yet? It makes the car a lot more drivable with no software modification necessary. Try it. You won't be disappointed.
I am still working on the TCU and ECU, but I haven't had much time to spend on it lately. My little girl has started crawling and I spend most of my time supervising her so she doesn't eat stuff that she shouldn't. When I finish figuring out how to modify the TCU shift patterns I'll post the information here. You made a very valid point about the AT OIL TEMP light. It should be an easy thing to change and I'm going to do that on my car as soon as I'm sure I've figured it out correctly. From what I can tell, the overheat shifting mode activates when the temperature rises above 233F and deactivates when it falls below 230F. But I think the light goes on at 244F and off at 238F. I need to do more work on it. The plan is to modify the TCU program so that the temperature limits are in RAM not ROM and then I can tweak them in real time and monitor what happens. Phil.
Re: TCM Crack
So yeah... progress on this yet? I just got my Level 10 Transmission and I'm iching bad for a new TCU
Re: TCM Crack
Try a shade over 200 degrees as even the best ATFs like Mobil 1 have a flash point of 212. Average ATF is around 206.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Re: TCM Crack
I posted some info about how to mod the TCU a while back. LAN posted some improved shift maps.
Your best bet is to buy a ready made one from LAN. I assume he also knows how to change the temperature that triggers the warning light. See this thread: http://www.subaru-svx.net/forum/showthread.php?t=46581
Thread Tools | |
Display Modes | |
