Old 12-27-2004, 01:04 PM
Guard-TL-'s Avatar
Guard-TL- Guard-TL- is offline
Send a message via AIM to Guard-TL-
So I was driving last night......
the rock was huge....
The only real damage was the rim exploding, rotor breaking apart and smashing the ABS 'ring' (not sure of correct term). But on bright side almost no body or suspension damage considering the force of impact.
In the next picture, whats the correct name for the ABS 'ring' and where can I get a replacement (circled in black). And circled in blue how hard am I supposed to hit the bolt with a hammer to get it out. (I was going at it for a few minutes.......bigger hammer time?)
Also does anyone have an extra cross drilled/slotted rotor I can buy?
Your telling me that my bottle of soda has more displacement then your honda O_O
-1992 Pearl White Subaru SVX
-1995 Briliant Black Mazda Precidia (sold :'( )
-1996 GMC Sonoma ZQ8 pickup
http://www.subaru-svx.net/photos/fil...-TL-/20502.jpg
-Taras
Old 12-27-2004, 02:04 PM
n00b on demand's Avatar
Holy crap man...explain how that all happened
Old 12-27-2004, 02:06 PM
Ciscokid
WOW....that is nuts!!!
Good luck getting what you need
Old 12-27-2004, 02:14 PM
Guard-TL-'s Avatar
I will take pictures of the place and the thing that I hit tonight. Because to tell you the truth I can't put it in words.........just that it was a 'big' rock.
-Taras
Old 12-27-2004, 02:16 PM
Guard-TL-'s Avatar
I'm bidding on the tone ring right now (thx Dayle). I just need to find a rotor now, to get her back on the road.
-Taras
Old 12-27-2004, 02:17 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
Ouch!!!!!!!!
Old 12-27-2004, 02:22 PM
Kurt_W Kurt_W is offline
^ has Subaru issues
Send a message via AIM to Kurt_W
Knocking the stud out shouldn't be particularly hard. I knocked a couple bad studs out of mine with a ballpeen(sp) hammer without any fuss. You might want to hit it with some PB Blaster or the like (though I can't imagine the penatration being all that good) and let it soak a little while. Either that or hit it with a 4lb sledge and see if it will pop out. Shouldn't come out on the first hit but shouldn't take very many. I suggess getting some spare lugnuts to pull the new stud in since the factory SVX lugs are made of pretty soft metal.
HTH
Kurt
'04 WRX SW - WR Blue - 26000 mi
'95 SVX L-AWD - Green - 143k
'92 SVX Ls-L - Dark Teal - 67300 mi
'91 Miata - a lot-o-miles
'88 CRX Si/B16 not-so-SiR
'73 Datsun 240Z
Old 12-27-2004, 06:06 PM
Subafreak's Avatar
Superbeast
Ouch! I guess you lucky the wheel took the impact and not the control arm. Still I would get the alingment checked when your done.
You know you have to change the wheel bearing to change that tone ring right? What would bother you more, not having ABS or the light being on in the dash? (Unpluging the ABS computer under the seat gets rid of the light )
Good luck getting it all back together. And try not to hit any Really BIG Rocks!!! Whats the real story behind this? What were you doing that you shouldn't have?
Old 12-27-2004, 06:47 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Wow, must be a big solid rock.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 12-27-2004, 10:58 PM
Guard-TL-'s Avatar
^ ^ To clear this up a bit. This accident was completely my fault, I took the corner way too fast for the road conditions (covered in snow and ice). And I struck the rock sideways at a weird angle. The wheel was probably two feet off the ground when it struck the rock. I will take a picture tommorow, it will explain better.
-Taras
Old 01-05-2005, 04:56 PM
Are the pictures in another thread?
