Old 02-15-2010, 02:26 AM
NeedForSpeed NeedForSpeed is offline
Re: Speed Sensor #1
Originally Posted by b3lha View Post
Here's another question for the gearbox gurus:
Does the US Front Wheel Drive transmission have VSS1 inside the transmission, or only VSS2 in the front diff?
If I recall correctly, the FWD trans has a flatter rear housing, more like a cover, since there is nothing but two gears to drive the pinion shaft to transfer power from the main shaft to the front diff, therefore no sensor on the housing .
I can't say if I saw the FWD picture posted here or elsewhere.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 02-15-2010, 02:43 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Speed Sensor #1
Originally Posted by TomsSVX View Post
yes it is inside... From what I can remember it uses the parking prawl gear as its pick-up
Thanks Tom.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 02-15-2010, 02:48 AM
Re: Speed Sensor #1
It's inside
That's why I didn't see it outside
Tom may be one of the few that has taken apart a FWD transmission.
Disregard my last post
Old 02-17-2010, 01:36 PM
Re: Speed Sensor #1
Ok, as far as changing the constants in the TCU for the different diff ratios, wouldn't a simpler way be to change the tcu along with the gearbox. I've been wondering why the tcu isn't normally changed anyway.
Also, I'm curious: why would Subaru use all the different layouts for the speed sensors in the different markets. Doesn't seem cost-effective for them to have done that. So why did they?
