Old 03-11-2006, 12:01 PM
Nobody Nobody is offline
Send a message via ICQ to Nobody Send a message via MSN to Nobody
Anybody parting?
Hi, just looking for right tail light and right mirror (all inner parts which moves with mirror).
Thanx for letting me know.
Petr
Petr
"It is never bad enough, it could always be worse"
Old 03-11-2006, 02:12 PM
Petr
Hello Petr
What happened your tail light? I can't help you with that one, I don't have a spare.
I do have a rhs mirror. It has all moving parts, heater etc. The problem is, it is from a RHD car. You would have to take it apart, and move the position plate in the base to have the angle properly set for lhd use.
Also as it is a driver's door mirror, then the glass will be flatter than the glass in a rhs mirror from a left drive vehicle. You would not see such a wide field of view, for one thing, vehicles dazzling you from behind at night would be another problem.
Is it not possible to get one on the continent? I saw a parts car advertised in Germany recently. I will look up the link for you.
Old 03-11-2006, 02:18 PM
Petr
Have you checked this one?:
http://cgi.ebay.co.uk/Subaru-SVX-Spi...QQcmdZViewItem
Old 03-11-2006, 03:46 PM
Another one!!
Here's another link Petr
http://cgi.ebay.com/ebaymotors/Subar...temZ8038557793
Old 03-12-2006, 01:49 AM
Hello Joe, it is long distance run as I am planning replacing it from times I had bought it. As for mirror, there is broken one part which moves/adjusts mirror angle. I have tried to glue it several times but never last for long as brokes again. As for tail lamp, I have problem with watter entering it regullarly. Tried to solve it several times with no luck. I have check it thoroughly and found out that it is somehow deformed by heat and so it is not possible to seal it, strange thing:-(. I do not like ebay as I have bad experience with it, trying to find whole car fot parting but for a long time only US spec. available here...
Thanx for help.
Petr
Petr
Old 03-12-2006, 05:20 AM
Thanx for help.
Petr
You are welcome Petr.
So what are you saying? Would it not be the closest in distance and shipping for you to buy the green German one?
I can sell you the black one I have if you want it. You would need to adjust it as per my post, but likely you could just take out the broken part from yours and replace it in your shell with the good part from mine. If you want it, PM me, we'll talk.
Cheers
Old 03-12-2006, 08:40 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Hi Petr,
Bryan is still breaking his car, I was chatting to him a couple of weeks ago. Not sure whether he has the parts you want.
http://www.subaru-svx.net/forum/showthread.php?t=26656
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
