Intake work for the Racer
Well, the paint is dry, now all we need to do is cut away some of the rad support to be able to fit this
In place of the passenger side headlight. As far as we can tell this should fit into the rules for both SCCA and Grassroots Motorsports. I started by disassembling the passenger headlight and cutting away the back section for the HB and Fog. Then I used styrofoam to carve the mold for the funnel to be fiberglassed. This was my first fiberglass work, although that is fairly obvious if you notice the roughness. Once I was finished with the Fiberglass work, I cut away most of the front lens and replaced it with a 1/2" wire screen. Then some chrome paint for the funnel and black paint for the outside... From the funnel there is a 4" aluminum tube shooting straight across (where the AC Dryer and ABS used to be) into a new 4" hole cut into the front of the stock airbox. More photos of the project here
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 10-30-2007 at 07:57 PM. Reason: update photo links |
Nice.....and still get to retain the low beam projector lens.....
I likey...
Just hope it doesn't rain.....
Make sure the drain hole in the bottom of the airbox is clear....so any water going it, can drain out.
Dave,
Very nice!! Did you use the Turtle Wax as mold release? I think you're going to like the results -- it's very similar to what I did with my ram air set up, except I adapted an existing injection molded inlet to the 4" flex tubing I ran to the airbox. Again, great job!! -Bill
I already enlarged the drain hole at the bottom of the box, I'm thinking of adding a drain tube to prevent the sucking in of hot underhood air??
Yeah, that's what the turtle wax was for, If I did it again, I'd probably do it without the wax, It seemed to make more of a mess than it was worth. The places that weren't waxed released just as easily
