Old 05-18-2010, 07:28 PM
A New Friend For My SVX
My SVX has a new friend in the Driveway!!!
2010 Subaru Legacy
Couple Shots I took between Rain Storms:
The Legacy may be newer and better, but the SVX is still teh sex!
If only the SVX had the Legacy's Lineartronic™ CVT (Continuously Variable Transmission) with 6-speed manual mode and paddle shifters.
Old 05-18-2010, 08:31 PM
BoxerFanatic's Avatar
Re: A New Friend For My SVX
Wow, that car is huge, compared to even an SVX.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 05-18-2010, 08:40 PM
sabin sabin is offline
Banned
Did you get the 3.6 ?
Old 05-18-2010, 09:30 PM
Yes its is huge. That was my first though after seeing it in the driveway.
It didn't seem so big at the dealership, specially after test driving the forester.
Its got to be a foot taller than the SVX.
No it is not a 3.6R.
It is a 2.5i Premium.
Additional Options:
Trunk Spoiler.
http://www.subaru.com/vehicles/legac...ium/index.html
Old 05-18-2010, 10:05 PM
Banned
your first post was throwing me off, i see you edited it
2.5 comes with a cvt the 3.6 comes with a 5eat
i have 5eat in my outback and i wish i had one in my svx
some info on subaru automatic transmissions and awd systems
Active All wheel drive found in the 4eat and the cvt
The mechanism that transfers torque fore and aft is contained within the transmission’s tailshaft. To the casual observer it looks just like a typical hydraulic clutch found in any automatic. The key difference in this clutch pack is its operation. It’s designed to slip according to how much all-wheel drive is needed. When an automatic’s clutch slips, it is due to a malfunction and will eventually burn up. But the multi-plate transfer (MPT) clutch uses a special friction material that easily withstands the friction loads generated during torque transfer. (Also referred to as VTC = Variable Transfer Clutch)
The MPT’s operation is controlled by the Transmission Control Unit (or TCU) and constantly changes dependent on how the vehicle is being driven. To get more all-wheel drive, the TCU increases the hydraulic pressure to the clutch for less slippage. Less all-wheel drive calls for more slip and the TCU reduces the hydraulic pressure to the clutch.
Under normal, dry pavement operation torque split is about 90% front and 10% rear. This distribution helps to compensate for the car’s weight distribution and resultant smaller effective rolling diameter of the front tires. As weight transfers to the rear of the vehicle, (i.e., under acceleration), the TCU shifts the torque split more toward the rear wheels. Under hard braking, torque is directed forward. Torque distribution is changed based upon how the vehicle is being driven. Throttle position, gearshift lever position, current gear and other factors combine to influence the TCU and it, in turn, selects a software map that determines how aggressively torque split will be adjusted.
MODELS WITH FIVE-SPEED AUTOMATIC TRANSMISSION – VARIABLE TORQUE DISTRIBUTION ALL-WHEEL DRIVE: As with Active All-Wheel Drive, an electronically controlled variable transfer clutch distributes power, but through a planetary-type center differential and a viscous-type limited-slip rear differential. Torque distribution is normally configured at a performance-oriented rear-wheel-biased 45/55 split front to rear. Sensors monitor the same parameters as for Active All-Wheel Drive
nice looking lego
Old 05-19-2010, 04:01 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Looks like a Maxima's cousin. Congrats on the new car.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-19-2010, 07:50 AM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Wow, thats a big car!! Make the SVX look like a kei car.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 05-19-2010, 12:14 PM
NeedForSpeed NeedForSpeed is offline
It didn't look that big when I passed one on the freeway yesterday, but parked next to an SVX, it's huge!
I always thought the SVX was big for a 2-door.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-19-2010, 12:22 PM
RSVX RSVX is offline
Network Design Administrator
Enjoy your Camry...
Life is a game. Play to win.
Old 05-19-2010, 12:47 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Do you have any under-hood shots of it? I know it's just a bunch of black plastic under there, but I can't for the life of me figure out what they've got in there to fill up all that space. I mean, you could stack 2 EG33s under there and still have room, so other than a 2.5L motor what else is in there? I'm picturing a bedroom set with nice floor lamps and a king size bed.
Congrats on the purchase. I don't want to come off like I'm knocking it. It is a very nice looking car. I like the Merc S-Class fender flairs and the CVT should be pretty cool (as long as they've improved it since the Justy). I just can't figure out why it's sooooo BIG. I'd love to see it parked next to a first generation Legacy. When I went from a '92 Lego to the SVX my first reaction was "man this thing is huge".
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 05-19-2010, 01:26 PM
I know black is a slimming color, but that is a huge difference.
And supposedly the Legacy (34-3500lbs) weighs less than the 3600+ SVX
I still wish for a car to come from Subaru that combines the best of the SVX and 05-09 Legacy and WRX STI, on the physical length of the 08+ impreza, minus a lot of vertical height, and with SVX's sleekness.
I hope the new Legacy serves well.
Old 05-19-2010, 01:38 PM
Seems the pics are deceiving, or doctored
The pic taken from the rear of the SVX shows a different size relationship.
Parking the cars side by side would make better shots.
Old 05-19-2010, 02:18 PM
dcarrb dcarrb is offline
I went from a ’90 Legacy to the SVX and thought the same thing. Even now, when I ride in my friend's late-model Outback, it seems cramped by comparison to my cars.
Sitting in traffic, I've noticed the trunk lid on some cars seems to be at my eye level from the vantage point of the SVX.
Congrats on the purchase, Lookin4SVX.
dcb
Old 05-19-2010, 02:46 PM
First off, let me clear something up, it is not my legacy.
I just said my SVX has a new friend in the Driveway.
It is my moms new ride, the grocery getter.
She works about 1/2 mile down the road, she just got it.
Second, I agree that it is an ugly car.
3rd, Photos are not doctored other than my ugly house background are blurred.
4th, I will get shots with them side by side and all sorts of angles.
5th, I will get shots under the hood.
Old 05-19-2010, 03:09 PM
Originally Posted by RSVX View Post
Enjoy your Camry...
Now come on, Camry's don't have BOXER engines,
yet
And, when and if, that would make a Camry a SUBARU
