BOTTOMING OUT! >> Struts?
My SVX has been prone to bottoming out [in front] in dips at all but very cautious speeds! IS THIS NORMAL FOR THE SVX or should I replace the front struts (and/or springs) [with OEM or aftermarket products]? I have clocked about 75,000 miles.
THANKS FOR YOUR THOUGHTS!
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 09-15-2003 at 02:14 AM. |
It's quite normal to scrape the front especailly when driving over dips (driveways, gutters). Still you might have a leaky strut(s) that might make it worse. The only wayt to tell is take the wheel off. Strut replacement is quite frequent around 100K. Mine have been leaking since 88K.
If all else fails, you also might want to cut out the big macs! Last edited by JLittell; 09-15-2003 at 12:47 PM. |
Typically, strut suspension has reduced (effective) suspension travel compared to unequal a-arm suspension. Weak struts will exacerbate the situation. Slow down and defer their replacement or replace them and find that you still need to slow down - just not quite as much. The only proper way to check the springs is to measure the ride height (anyone have the specs? if not I can probably find them somewhere) and compare to spec.
Re: BOTTOMING OUT! >> Struts?
Great to again have yout expert advice. As you have made a request the following figures may assist. Wheel Arch Height. ( From the official Japanese RHD manual ) : - Measurements from center and highest point under edge of wheel arch to the the center of the wheel hub. Front. 380 m.m. +10 , -20, or 14.96 inches + 0.39, - 0.79 Rear. 335 m.m. + 10, - 20, or 13.19 inches + 0.39, - 0.79 Sincere regards, Trevor.
bottoming out!
Yes, I'm bottoming out! Hitting the bumpers after compressing the strut/springs to the max! I started to be concerned, when I went over the same bump (by work) with a friend's car - It took it much better!! I know our SVX's are heavy - Maybe that's a lot of it?
Thanks!
Re: bottoming out!
I have pretty old struts on mine (stock and 196k on them) My car definitely sags a little and sits lower than my wifes svx. In the rear the top of the tire is even with the fender where it is about an inch clearance on the wifes.
There are pictures from the dragon where the body roll is so bad it looks like I lifted the inner rear tire off the ground. I still have never bottomed it out and I do not slow down for bumps/ railroad tracks(within reason). I'd check the struts for leaking as seggested and check the ride height.
NEW STRUTS - Which Kind?
I have just about decided to put all new struts on my SVX. [Partly because of my bottoming out problem up front, but also because someone suggested that what appeared to be a front (steering wheel shook!) suspension problem while braking recently on gradual downgrade in mountains (which was solved totally by replacing rear rotors alone!) might in fact have been an (obviously) warped rear rotor(s) exacerbated by shaking through an inadequate shock (strut) damping mechanism. Soooo . . . .
MY QUESTION IS: Which struts should I get to obtain a stiffer (improved less bottoming affect) yet Cadillac-type ride (like our SVX's are famous for?) 1. OEM's 2. KYB's 3. Koni's 4. Other? THANKS AGAIN FOR YOUR HELP!
I have the Konis at all four corners and love them. I keep them set pretty high, and the ride quality is still more pleasant than stock. A little firmer than stock over low speed bumps, but just as nice on the highway, and the car loses almost all of its "floaty" nature in bumpy high-g turns. They make the car feel and respond much more "sportily", and if they fit your budget, I highly recommend them.
If you go that route, there are some good install notes on this site. A large diameter tubing cutter will save a lot of time and effort, and I would suggest you have an old bike inner-tube handy to cut up and "shim" the rear insert in the housing, as it does not fit snugly like the front. -Mike
First the smiles, then the lies. Last comes gunfire. |
Re: NEW STRUTS - Which Kind?
Maybe I'm wrong, but I seem to remember Gabriel making an SVX strut. However they were like $299 per axle - which is pretty stiff for the medium grade strut from that brand, non-adjustable, etc.
I just changed my rear struts w/OEM and I seem to remember seeing the name Showa on the body. While it doesn't have the adjustability of the Koni, it's a respected brand - at least in motorcycle circles. Let's all try to talk Porter into the R&D for a set of Ohlins |
I think the struts leak fluid from wheel vibration and bumps. It just goes out the seal after sometime. I am thinking about drilling and tap'en holes the next time I need struts and fill them back up.
