Bearing Type Whine . . . . .
I replaced both the front and rear bearings last year. After replacing the rears early last year, I still heard a whining sound which seemed to come from the front. Later in the year, I replaced the fronts, but I still hear at times a definite (slight to moderate) whining sound. I don't think either front or rear bearings were done incorrectly nor do I think they've gone bad right after the replacements were made (as some say is possible: bent hubs, lugs overtightened, etc.). My best guess on the rotation rate on the rotational whine is at a faster rate than the wheels (?). Could it be the driveshaft U-joints? [I replaced the front axles (one bad boot) late in the year also.]
What do you think could be making this haunting whining noise? THANKS for any help!
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 01-20-2004 at 02:34 AM. |
Try some new tires. My Dunlop Sport FM-901's whine a bit . . .
I do know that transmission end bearings can cause what you are describing, but I'm pretty sure thats not what you want to hear.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
WHINE
It's not so much of a (constant) whine as it is a "Yah!...Yah!...Yah!...Yah!" cyclic type of sound. It seems to be faster than the rotation of the wheels, so might be driveshaft, front differential rear bearing, rear differential front bearing, etc.
I guess it could be the rear trans bearing? I'm gonna hafto find a wing-walker that wants to be strapped to the undercarriage (very thin person!) of the SVX while I drive around to diagnose the problem! THANKS for your input!
