ATF FILTER KIT ON POST-92 SVX
I have the Subaru external filter kit with hoses that was designed for the 92 SVX. I thought I would install it on my 96 and then get a full tranny flush.
I downloaded the TSB on how to install it so that I could give it to my mechanic for installation. Here are my questions: 1. Since I have the newer radiator without the mesh screen in the cooler how important is it to backflush the cooler? It says not to bypass this procedure. 2. The TSB refers to various "figures" (diagrams) to follow but they are not shown. Does anyone have a copy of these illustrations? 3. Most important: Since we have recently found out that the diagram for IN and OUT ATF flow through the radiator was wrong in the original service manual, how does that affect the written TSB? http://members.tripod.com/quick_svx/.../42748095.html I don't want to follow the TSB to the letter and find out it was hooked up backwards. Or should I just use an aftermarket filter system and forget all about the one from Subaru? A written diagram or explanation would be helpful.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-20-2003 at 11:39 AM. |
