cigarette lighter fuse help
Do you know what fuse and where its located thanks
Re: cigarette lighter fuse help
First column 5th row labeled Cig/Mirror a 20AMP.
Also this link might be handy if you are having issues with it blowing a lot http://www.subaru-svx.net/forum/showthread.php?t=52869
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
If replacing the fuse doesn't help, it may be the fusible link installed at the rear of the lighter assembly. .... For some odd reason mine failed and I thought it was a bad lighter assembly and decided to replace it. After I got the old one out I noticed the fusible link had blown. I have never seen this before and am not sure why it it would blow instead of the fuse. In the picture above you can see the shriveled portion of the fusible link where it melted. I did a continuity test between both ends and it read open. I replaced the fusible link with a piece of heavy-gauge straight wire. Absolutely no problems since. I normally would not do this, but I only use the lighter socket for very low current items, like my cell phone charger (1.5A), and my plug-in voltmeter. Would never use it for a high-current draw (heat) item like a cigarette lighter. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-13-2017 at 09:11 PM. |
Thank you for your help it was the fuse I pulled it out and it was done lol that is the last time that I plug in my radar dectector. And 2 phone chargers lol what is the limit b4 I blpw the fuse?
If it's a 20 amp fuse, I'd say around 19 amps if you want to push the envelope. |
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by svxcess; 10-28-2017 at 11:21 PM. |
Now that's a great idea.
Removing the fusible link, not such a great idea! Along the lines of removing the batteries from your smoke detector. I wonder if all car lighters have this safety feature built in? |
