Old 12-14-2011, 05:58 AM
Vettein93's Avatar
Vettein93 Vettein93 is offline
"stop lamp" light
All of brake lights are working but on the dash the "Stop light" continues to go on once I hit the brakes. Any ideas
Old 12-14-2011, 06:37 AM
Re: "stop lamp" light
http://www.subaru-svx.net/forum/show...ight=STOP+LAMP
Old 12-14-2011, 07:24 AM
Have you replaced a burned-out tail light recently?
The stop lamp checker uses the amperage difference between the trunk panel and the two body-mounted stop lights to determine if a bulb is bad. Very similar design to a GFCI outlet in your house.
If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker even if all four bulbs work.
Bulbs are dirt cheap so when I have one go out, I replace all four with the same brand.
This is the easiest place to start.
Old 12-14-2011, 08:02 AM
Could be low on brake fluid also
Old 12-14-2011, 08:18 AM
Not likely. The "STOP LAMP" bulb in the dash indicates a problem with the lighting circuit only.
The "BRAKE" indicator light usually means low on brake fluid.
Old 12-14-2011, 08:37 AM
OK confused as to what light he was talking about . Then I stand corrected . NEVER MIND
Old 12-14-2011, 12:40 PM
Green1995SVX's Avatar
The misinformation you've been posting lately with complete confidence is becoming insane!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-14-2011, 02:13 PM
Manarius's Avatar
Manarius Manarius is offline
If I recall correctly, the "BRAKE" light will come on if the brake fluid is low. However, the "STOP LAMP" light is a quite different animal and is not related to the fluid level in the slightest.
-Jason
-Obi Wan Kenobi
Old 12-14-2011, 02:19 PM
I would not call "Could be ", a statment of "complete confidence ".
Old 12-14-2011, 02:30 PM
He said that it "could be" that with complete confidence. There is no possible way that being low on brake fluid would cause the "Stop Light" indicator to illuminate.
So no, there's no way it could be what he thinks it could be.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 12-14-2011, 02:45 PM
"Would be" is a statement of confidence.
I would not jump on someone for offering an explanation, everyone has to learn.
Old 12-14-2011, 03:14 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
It is true, though, that not being sure is a good reason for not typing when it comes to technical information. We have enough veterans here to speak!
Old 12-14-2011, 03:29 PM
i agree that wrong info is sometimes posted, that is what a learning process is. If we left it to "Veterans only", these boards would be very bare.
Old 12-14-2011, 06:17 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Please don't squabble. This forum is a place for being open and honest. There is no need to be negative. We all have something in common - we love the SVX.
There is enough negativity in the world.
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 12-14-2011, 06:44 PM
immortal_suby's Avatar
Thread Killah
I consider myself pretty well informed in the area of general svx knowledge, and I still make mistakes here on advice. I guess I'll just stop posting as well to avoid giving the wrong advice with too much confidence.
Sheesh.
Locker Link
2015 BRZ Limited 6MT
