Old 07-24-2006, 06:10 PM
Originally Posted by b3lha
Do you have any more info on this, Trevor? I'd like to try it but I don't see anything about it in the owners manual - admittedly I am only looking at the pictures because I can't read Japanese!
Here you go Phil,
http://www.subaru-svx.net/forum/show...76&postcount=9
Old 07-24-2006, 09:35 PM
dynomatt dynomatt is offline
Couple of things I noticed on my 91 JDM CXW front cut that I recently stripped:
1) Plastic headlight lenses
2) Fog lights inboard of high beams (3 bulbs in lights)
3) Fog light switch next to park light switch (might be an Aust spec thing)
4) Audio controls on steering wheel
5) Keyless entry module was under dash (versus driver side rear in my 95)
6) confirm folding mirrors - has an extra button on the mirror switch
7) Confirm "Boxer" on throttle body cover
I have most of these things which I'd be happy to sell if somebody wanted to be a bit different. I'm keeping the headlights though.
Cheers,
Old 07-25-2006, 12:00 AM
Greetings Phil,
I see that you will be getting a PM from our man who really knows his stuff and in Japanese.
Not surprising that Harvey is off with the thunder.
If you require any more detail let me know. There could be the bits required available from a local wrecker/breaker. If you want me to investigate shout, but I would imagine that you could be in for some frustrating and extensive work.
Cheers, Trevor.
Old 07-25-2006, 01:49 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Thanks for the info guys, that coded lock release is so cool. As the manual pages in Harvey's locker are in English, I infer that this system was also fitted to Aussie SVXes and possibly European ones too?
It works perfectly on my 94: I set a code as per the instructions. Then I locked the door, put in the code using the handle and the door unlocked itself like magic!
It seems to be broken on my 92. I'll check the wiring for the central locking because it was badly butchered by the guy who installed the alarm. Or maybe this car never had it - although the infra-red key used to work and one would assume they are controlled by the same module.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 07-25-2006, 05:49 AM
Good one Phil,
I did not realise that you simply wanted to know how to work what you already had. Now you know what you have been missing. If you require any bits for the 92 you know where to ask.
Enjoy, Trevor.
Old 02-14-2007, 12:34 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Cheers,
PM sent Matt.
Old 02-14-2007, 01:16 AM
Cheers,
What is the VIN on your 91? Mine is CXW002430. I may be interested in the keyless entry module if mine does not work.
Thanks
Old 02-14-2007, 01:25 AM
I did not know what the little window on the handle was until now. I see that it is IR system. Thanks for the info. Now all I have to do is find a key with it.
Old 02-14-2007, 03:22 AM
11,000 Posts!!!
Congratulations Earl. 11,000 clocked up.
Old 02-14-2007, 07:21 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
more horse power - 240ps
heated seats as standard?
no auto seatbelt on 92s
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-14-2007, 07:33 AM
I don't believe the JDM cars are any more powerful that the rest of the world.
Danny in the Lebanon, his car came as standard with no cats. This seems to be the case for some markets. These cars would be freer breathing and may have a few extra ponies. Not too many, but some for sure.
Heated seats was standard in the UK, probably Germany also. I've never seen a JDM car with the heated seat switches, so I don't think that market got the option. I'm open to correction though.
Paddles?
It's very possible the only market that got auto seatbelts was the US.
Old 02-14-2007, 08:15 AM
ItsPeteReally ItsPeteReally is offline
Neither do I.
240 ps equates to 236.7 horsepower (actually 236.716839671943048 hp).
But 240 is a suspiciously rounded number in the first place!
The US specs quote 230 horsepower, also a suspiciously rounded number.
How were these measurements made? We don't know.
We can assume the engine was on a test rig somewhere and not actually mounted in a car; and most probably not using the original car's inlet and exhaust systems either. There is no mention of the fuel used, the air pressure, air temperature, coolant temperature etc. etc. etc. Was the engine driving any ancilliaries such as the generator and power steering pump?
Were these two measured values the really the same, or were two different measurements made on different engines under different conditions?
I don't know. What I suspect is that the natural production variations between any two cars coming off the production line are likely to show greater variability in power output than any inferred differences between these two power figures.
My suspicious mind thinks that these power figures are probably higher than you could get from any engine actually installed in a car .
I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind; it may be the beginning of knowledge, but you have scarcely in your thoughts advanced to the state of Science, whatever the matter may be.
Sir William Thomson
Old 02-14-2007, 02:10 PM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
Paddles?
No heated seats on JDM models.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 02-14-2007, 05:16 PM
Thanks Paul, I thought not.
Old 02-15-2007, 11:32 AM
zavikan zavikan is offline
Whoaaaaaaaaaa
Coded door release w/ infared thingy key?
Can some one explain this more simply?
Is it possible to adapt this to a USDM?
WHAT PARTS WOULD I NEED TO DO THIS!?!?
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
