Old 07-19-2006, 07:17 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Unhappy LITTLE things that IRK you about the SVX
I'm not referring to the more obvious SVX problems, i.e. transnmission failures, warping rotors, bearring replacements but list the small items like drooping sunvisors etc etc.........
What ticks me off almost daily is the release button on the center console. My elbow just seems to fit right in that exact spot. So the console is forever being released and lifts up when i lift my arm up AARRHHHHH
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 07-19-2006, 07:21 AM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
same problem!...
something else i've noticed... (since i had a saab 9000 cse before my svx) when i close the svx door with the window open, the glass clatters around sounding very cheap....
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 07-19-2006, 07:27 AM
SubaSteevo's Avatar
No longer blue member
I have an annoying interior rattle from the right rear. I've taken the entire rear apart to try to find it, and dynamatted with no luck.
My solution thus far has been to turn up the volume on my stereo.
-Steve
01' MSM Lexus IS300
Old 07-19-2006, 07:39 AM
RSVX RSVX is offline
Network Design Administrator
check the little plastic cover for the child restraint system in the speaker grill.
Life is a game. Play to win.
Old 07-19-2006, 08:14 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
i have the same problem and have checked the little tab as well...though i have my guesses on a few other things..need time to take it apart
Old 07-19-2006, 08:50 AM
SubaSteevo's Avatar
That was the first thing I took off trying to fix it.
-Steve
01' MSM Lexus IS300
Old 07-19-2006, 09:56 AM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
My passenger side window seems to be off the track or something because it won't close all the way without help from me.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 07-19-2006, 10:04 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
My center consol never opens...I have to slide it back slighly with one hand, then push teh button with the other.
People who slam my doors from the passenger side...the window will rattle...but geesh...not so hard!!!
Scratches on my driver's window...they r buggin me
Turning the a/c on , right away the fan blows on full blast...sounds like a shop vac...I always have to set the fan to low...WTF!
Sweaty back in warm weather from leather seat...even w/ shirt on....lol
Radio door slightly interferes w/ ashtray door and I need to manipulate the door with pinky and thumb to open.
Um that's it until I think of more
1995 Subaru Svx L / AWD
Old 07-19-2006, 10:56 AM
intellibomb's Avatar
intellibomb intellibomb is offline
worn out ass stock shocks that bottom out everywhere
the guide on my drivers side window is fukt and the glass is now scratched.
the wrong color front window
my trunk lid, always getting slammed, even if gently dropped.... you have to set it down, then click it closed.
oooh
when the security system is not armed and you push the remote button: "Beepbeepbeepbeepbeepbeepbepp" as opposed to "beep" and "beepbeep"
Old 07-19-2006, 11:02 AM
2 hands on the wheel, sir.
Old 07-19-2006, 12:31 PM
n00b on demand's Avatar
Mine too!!
Old 07-19-2006, 01:15 PM
dcarrb dcarrb is offline
The most irksome thing about an SVX? Fake wood.
dcb
Old 07-19-2006, 01:22 PM
Actually i do NORMALLY keep 2 hands on the wheel but instead of the 10/2 o'clock position my hands are normally in the 8/4 o'clock positon or maybe even 7/5, so there for the right arm is normally on the center console and left arm on the door console, pretty comfortable. That changes depending on traffic... then there are the times when the knee is doing the steering but we will not talk about that, it drives my wife crazy.......
HENRY
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 07-19-2006, 01:27 PM
[QUOTE=msvx95]My center consol never opens...I have to slide it back slighly with one hand, then push teh button with the other.
The console thing is easy to correct. Loosen the 2 screws that hold it in place. Then tighten it while sliding it back as far as you can towards the rear of the car. Just did that this weekend because one of the screws had worked itself loose. Now i can push the release button and she pops right up.
HENRY
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 07-19-2006, 01:30 PM
Originally Posted by intellibomb
when the security system is not armed and you push the remote button: "Beepbeepbeepbeepbeepbeepbep" as opposed to "beep" and "beepbeep"
That usually happens when the "SECURITY" button on the dash is turned off. The car's way of letting you know the security system ids not on. Press the button on the dash and try again.
