Old 08-13-2015, 11:47 AM
PhyrraM PhyrraM is offline
New to the SVX world, trim parts needed
Looking for:
Grey radio box or just the cover.
Driver's side power window switches.
Grey driver's and passengers visors.
Upper radiator mounting brackets, both.
Grey lower driver's side dash cover.
Thanks.
Old 08-13-2015, 02:51 PM
Re: New to the SVX world, trim parts needed
I've got a pair of rad mount brackets. I'll send you a PM.
Old 08-13-2015, 04:31 PM
Here are the OEM part numbers for some of these parts: You may be able to search the web for these.
45116PA000 upper radiator support. Available for less than $10.00 each
83081PA010 Master power window switch- These are available on ebay for $125.00-135.00 each
Gray sun visor left 92010PA073MH
Gray sun visor right 92010PA062MH
The visors MAY be available at about $185.00 each side. They may be hard to find without the drooping issues. They have been discontinued for some time.
The other parts may be available here.
Old 08-13-2015, 05:45 PM
I didn't know the brackets were so cheap. Because of the shipping cost you might as well buy new ones.
Old 08-13-2015, 06:07 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Originally Posted by PhyrraM View Post
Looking for:
Thanks.
Hello, PM Sent!!
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
