Old 03-28-2015, 03:46 PM
kysvx kysvx is offline
Starter, passenger cooling fan, driver side inner tie rod end
Looking for the following parts in very good condition:
-Passenger side cooling fan
-Starter
-Driver side inner tie rod end
If anyone has these parts available or knows where I can find them I appreciate the help.
Thanks!
Old 03-31-2015, 08:07 PM
Dan sr Dan sr is offline
Wink Re: Starter, passenger cooling fan, driver side inner tie rod end
I have mint condition starter =$50.00; - cooling fan pass. side $40.00
plus cost of shipping;
partstogo@gmail.com
Let me know if you interested;
Dan sr.
Old 04-01-2015, 12:02 AM
I ended up ordering a cooling fan assembly for a 94 altima since I've read that will work in the SVX. I will see how that works this weekend and get back to you.
Do you know if all SVX starters are interchangeable?
Thanks for the response
Old 04-01-2015, 07:37 AM
All of the SVX starters from AUTOMATIC transmissions are interchangeable.
Old 04-03-2015, 02:02 PM
Shows how much I know!
I tried to put in the cooling fan assembly from the '94 Altima today. The shroud setup was completely different and although the fans blades are the same size, the new motor causes them to sit out too far and scrape the radiator. The new motor and old blades are not interchangeable and vice versa either. So the Altima assembly is getting sent back.
