Old 07-01-2014, 10:17 AM
Tapani Tapani is offline
Manual left front seat rails
I'd like to install a pair of Recaro seats in my Toy.
At this time I think the easiest way is to use the mounts, rails and seat belt anchor from manual seats.
So, if any of you RHD guys have a passenger seat (LH) laying around and would like to part with the mounts and the rails only I would be very happy .
Pls see the attached illustration. This is all I need. Four bolts and the cable for the tilt mechanism is all that's needed to take out if you have a seat available.
Kind regards,
Tapani
Old 07-01-2014, 10:37 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Manual left front seat rails
You can use the manual rails from the passenger's side on the driver's side. This is what I did when I put racing seats in RacerX
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-01-2014, 12:16 PM
Oh, are they a direct fit?
The seat belt thingy can not be - eh? They are mirror images. I do not wish to modify the belt arrangement and I haven USM automatics.
Was there a manual LHD drivers seat available in the US? If yes, then I trust I could use these rails?
/T
Old 07-02-2014, 10:26 AM
So this is what I need for the LH side, pls see attachement.
Tapani
PS I also trial fitted the RH front seat from my 2006 Outback :-). The front mounts are almost a direct fit, but the rears need work.... the seat is a tad too high too. And the seat belt issue should be solved. The seat is not that much better, not worth the hassle and finding good seats.
Old 07-08-2014, 07:57 AM
JDM passenger side rails are on their way from the UK thanks to Mal . Thank you Malcom !
I trial fitted LT-L Recaros yesterday, I think they are a good compromise. Soooo much better than the OEM seat, but not as tight as the more track oriented seats. I only do maybe 5 track days a year so there's a risk of going too far in this area too.
I especially like the early -90's look - think about the Quattros of the era.
I am still waiting for a final quote for a pair, I hope it will be within my limits.
If this goes forward I will post another thread. Simple adapter plates need to be manufactured, the bolt patterns do not match exactly.
/T
Old 07-08-2014, 08:48 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Wow that really looks good. Good luck on the install
