Old 08-15-2013, 11:18 PM
Huskymaniac's Avatar
Uses the ignore feature
Question about 2.5L headgaskets
Does anyone know if the turbo engines got better head gaskets? I know there are other issues, particularly with the STi, but I am specifically asking about headgaskets in the lower HP engines found in the WRX and GT/XT cars.
Tony
Old 08-16-2013, 10:12 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Question about 2.5L headgaskets
Tony, from what ive heard all the 2.5's got bit by the same bug, although there is yet to be one on the current new body styles. Maybe they just last longer now than they used to. Im finding 07 and 08 years with head gasket issues and one I saw with only 83k miles. Why don't you find an EJ22T and put that in.
1995 POLO LSI 76K MILES SOLD
Old 08-16-2013, 11:48 AM
Are you talking about 07 and 08 turbo models or just the NA engines? I have read that both the 2.0L and 2.5L WRX engines had far fewer headgasket issues. There have been other problems with people who frequently romp on the STi engines but not usually headgaskets. That's what I read this morning. There will always be some HG failures on any model from people either not maintaining their cars right or abusing them or both but it sounds like HG issues on the turbo models occur at about 1/4 the rate as the non-turbo models.
Tony
Old 08-16-2013, 01:17 PM
The turbo engines are generally find for head gaskets. It's a completely different block, head, etc. Though, earlier models do have issues with cyl #4 due to improper fueling. It's the last cylinder on the fuel rail and leads to blown pistons (mostly ring lands) as well blowing out head gaskets on occasion. Typically though, they are more reliable from a head gasket point of view than N/A ej25s. If you do get an earlier one, be sure to have the screen on the banjo bolt removed. I personally like the WRX 2.0t engine over any of the AVCS (subaru's VVT system) engines when it comes to reliability.
Old 08-16-2013, 01:18 PM
An EJ22t is far from a straight swap(also a very rare engine to get ahold of), and aside from the block, it is only a SOHC engine and not great for performance unless you are building an engine for serious performance.
Rate This Thread:
