Old 05-01-2008, 11:42 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Radiator Leak
Umm so I parked my car and began to walk away when I heard a dripping sound. Sure enough there was a solid stream of coolant pouring out onto the ground. I'm guessing this isn't good?
Old 05-02-2008, 09:34 AM
wantafastsvx wantafastsvx is offline
Yea i would say thats not a good sign. Did you recently do anything to the cooling system? Is it possible you overfilled and when hot overflowed? If not i would check your hoses and the top of your radiator to see if its cracked. I doubt the crack as when mine cracked it was something you could here when walking away. Its sounds like maybe a hose ruptured or you overfilled or??? Where is it leaking from?
Old 05-02-2008, 11:08 AM
IceBlade's Avatar
It's coming out of the bottom and it wasn't just leaking it was like a steady flow. Can I put water in it to see where it's leaking from?
Old 05-02-2008, 12:19 PM
kwren's Avatar
kwren kwren is offline
are you sure...
that it is coming out of the radiator itself?
Old 05-02-2008, 12:37 PM
yup
i would suggest doing that to find the leak. I say either the hose or possible the petcock to drain the radiator is gone or leaking? Fill with water and see where it leaks from. When you find it let us know.
Old 05-02-2008, 03:54 PM
IceBlade's Avatar
Okay so I'm pretty sure the leak is coming from a hose. It's really hard to get to and I couldn't get it off. It's right behind the timing belt cover. I can't really explain better.. umm.. it's right below where the dip stick is. I'll try and get a picture maybe.
Old 05-06-2008, 07:05 AM
IceBlade's Avatar
So apparently coolant doesn't make you go blind.. which is good 'cause if it did.. I'd be blind. Does burn a little and doesn't taste all that great though.
Hmm so I finally got around to pulling the hose off where I thought the problem was but it was on there really good and I don't think that's where the problem is anymore. Actually the end of the black metal tube was rusted a bit. Could that cause it to leak? The hose was attached well past the rust. But either way I think it was leaking from further up under the intake manifold because everything's really dirty and wet under there. If I thought it was hard getting the other hose off.. this one's gonna be real fun!
On another note there's red stuff dripping off the middle of the timing cover (atf from the power steering?) and I think I'm leaking oil too. This is fun. I came back to my house drenched in coolant yesterday. I also got a nasty cut on my forehead from flailing around trying to get out from under my car haha.
Old 05-06-2008, 07:12 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Yeah, there is a hose back further under the intake manifold. Get a set of these and it's not too bad.
I used a short piece of off the shelf tube from the local auto parts store. Use a little lube on the hose so that it slides on easier.
Old 05-06-2008, 08:09 AM
IceBlade's Avatar
Is there a particular name for those tools so I can ask the guy in the store?
