Old 11-18-2011, 04:32 PM
The Molinator
"DeAd" battery.. intermittent.. ???
NOW my SVX battery is "dying" after being parked for a few hours (or sometimes for a few minutes!) .. very intermittently.. BUT, very disturbingly!
Two times yesterday.. and three times this week.. I had to be jumped (battery) to start my car.. after parking! When trying to start then.. wunt turn the engine at all enough.. lights dim.. LIKE A DEAD BATTERY.
BUT.. right after the second time yesterday.. I took my car directly to Pep Boys (after battery jumped 5 minutes earlier) 2 miles away.. They said AGAIN (3 times in 4-6 months now).. that BATTERY IS OK!!! ???
BTW, I have a $180 Interstate battery.
SO.. what cud cause this? .. Something while parked.. like brake lights (not on, tho).. that would involve a circuit that would be ON while parked .. with ignition key OFF! Maybe alarm?
Is there any other part to the start circuit (I replaced alternator, starter very recently) that cud malfunction when starting (a relay?).. ?? which would not be explained .. or require a dead battery???
Thanks, Jim
Jim
Old 11-18-2011, 04:58 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: "DeAd" battery.. intermittent.. ???
Look at the alternator wiring..Corroded?
Old 11-18-2011, 06:55 PM
The Molinator
I did the 4GA Mod for Alternator + wire a long time ago. There are some other wires coming off the same terminal on the alternator that are hidden in a strange long plastic sheath... Is that what you mean? .. Those wires?
Jim
Old 11-18-2011, 08:01 PM
Look at this thread
http://www.subaru-svx.net/forum/show...ight=parasitic
I posted links on how to check for a Parasitic Drain
Old 11-18-2011, 08:45 PM
I once had my rear wiper get stuck trying to park itself and it drained the battery. also the rear window defogger switch .
Have u used either in the past 3 weeks ?
Old 11-18-2011, 09:23 PM
Green1995SVX's Avatar
This is completely off-topic, but why is the A in "DeAd battery" capitalized? I've noticed that you do that a lot. I just wondered if there was a specific reason.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-19-2011, 06:44 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
Thanks, Jim
happened to me about a month ago...after a full inspection i noticed that the mirror heaters were on!
make sure that everything is off and check if the ground wire from the battery gets hot or not!(for short circuiting)
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 11-19-2011, 11:37 PM
I've seen batteries where the post is broken inside the case. Normally they make contact and all is fine, then they don't and it seems like a dead battery. When you put the clamp on, it moves the post and all is fine again.
It's an oddball thing but it has happened...
Old 11-22-2011, 04:15 PM
The Molinator
1) The same reason I answer, " Groovy" .. when people ask me how I am?
2) I'm different.
3) Better than BOLD.
4) Personalized ToUcH!
5) Retarded.
6) Hmmm?
Jim
Old 11-22-2011, 05:11 PM
The Molinator
How does an alarm fit in here? Doesn't an alarm draw all the time (when car off even, alarm ON)?
Jim
Old 11-22-2011, 07:19 PM
Not enough to kill a battery in 2 or 3 weeks
Old 11-22-2011, 09:28 PM
The stock alarm can kill the battery enough to not allow it to start in as little as 2 weeks. I've seen it happen on a fresh and good quality battery.
Old 11-22-2011, 09:56 PM
The NEWBIE
you mean 2 weeks for the alarm going off all the time? cuz my car had been sitting for more than 2 years before i bought it and the battery was sooo alive! (was locked by the alarm)
DIY FTW!
Old 11-23-2011, 12:38 AM
No, I have seen it happen. With no other faults or draws. It can happen.
I would also question any car sitting for 2 years and the battery still being able to start the car without a jump.
Old 11-23-2011, 03:06 PM
The NEWBIE
the smog date was from 2 years ago and the the mileage was 20 more than the one on the smog paper...chances are that the seller jumped it
but a battery being able to work properly after being decharged for 2 years is weird
but still 2 weeks is not realistic for my experiences! just sayin
DIY FTW!
