EJ22T pistons
I've been researching the hell out of the SVX for a couple months now (month or so before I bought it is when I started) And I have ran into something.
A lot of people are apparently using EJ22T pistons in the EG33 block. I mean it makes sense, it is basically an EJ22 engine with 2 extra cylinders added on. Now everything I have read of to this point is internet chatter. Some people claimed they run them and it lowers the compressions ratio. I would like to run them on my build, but a forged set and bore it .20 out. Let me know if anyone has any knowledge of this!
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
Re: EJ22T pistons
Who is running Ej22T pistons in an EG33? In this forum?
Man, compression will go waaaaaaaaay down to 7.1:1 (or something)... And THE SEARCH BUTTON is your bestestest friend
Re: EJ22T pistons
AFAIK stock compression ration on the EJ22T is 8.0, so that would be the same as the compression you should get on the pistons swapped into the EG33.
'93 Legacy LS (will last longer than the cockroaches) '94 SVX LSi |
Re: EJ22T pistons
Who told you that the head domes of both engines is the same for you to conclude that?
Re: EJ22T pistons
Do cranks have same rotational offset??? also are they both using same con-rod length???
Re: EJ22T pistons
well doing more research, the pistons will drop cr to 7.9:1 which is just fine for me. The rods ARE the same as all EJ rods EXCEPT for N/A 2.5 rods. There is some Journal differences but EJ22T rods have the same journal sizing (48mm i believe)
Re: EJ22T pistons
BTW, here you saw the 7.9:1 compression or was it here?
Re: EJ22T pistons
The NA 2.5L rods, years 2000 up are 1mm longer. The crank pin and piston pin are the same as SVX.
Use late 2.5L rods, and then trim the piston top accordingly. You will end up with a dish that is 1mm less deep, slightly raising the comp ratio. Of course the top ring will be 1mm closer to fire, but the compression distance is already substantial on these pistons.
