high level brake light fitment
hi, can someone tell me that the slot which is indicated on the rear boot lid suitable for a light, if so how can i obtain one and is it easy to fit & connect ?
thanks |
There should be a light in the wide narrow slot in the boot lid. Maybe we are not talking about the same place. Take a picture and post which slot you are talking about.
JDM (and USA) cars have a brake light in this slot, UK cars do not. The reason is that the cable into the boot lid only has four cores. On a JDM car these are Ground, Lights, Brakes and Reverse. On a UK car the "Brakes" wire is used for rear fogs, so there is no "Brakes" wire to power the high level brake light, so they omitted it. The blanking piece in the slot is actually a red lens that has been painted over. I remember reading that somebody managed to remove the paint from it and put a strip of bulbs behind.
It should be easy to obtain and fit a light, but you will have to run an extra wire into the bootlid to power it. On my cars I replaced the 4-core cable. I couldn't get 5-core so I used 7-core trailer cable. You just have to chop the connectors off the existing cable. Then you slide the rubber grommets off, lubricate them with soap, and slide them onto the new cable. Then you solder the connectors onto the new cable. There are some plastic cable guides which need to be warmed up and stretched a little to accomodate the fatter cable.
It was Arthur [ArthurUK] who used the existing strip and fitted LEDs to the empty light fitment.
You will probably be able to buy a second hand one by watching eBay on the US side, they often come up there for 10 to 20 dollars. Arthur's solution was simple and elegant. Take out the panel from the bootlid. It looks like a replacement, but is actually the light fitment painted over. Use paint remover to remove the paint from the plastic, and polish it up. Arthur then bought second hand LEDs from a Renault Clio in a scrap yard. These fit and worked. Remembering Phil's advice above about the four wires, you will need an extra wire to power it on. Connect this wire to one of the Stop light feeds, then run the wire up the trunk lid to the LED. You have a high level brake light for maybe a tenner. Joe
thanks for that info, i will prob look to fitone by the end of the year.
on a seperate note, does anyone know who own's P33 SVX in silver, i sold it 3years previously to a couple in south london. how's it doing? |
Joe is correct, just take out the blanking unit and remove the paint. I used fine sandpaper and wet&dry to polish it all off, it looks like new. Fitting the LED's is easy enough, I did use Renault Clio units, but any would do the job.
A couple of hours work. Arthur |
