Tachometer being interesting?
Already discussed this with OT... but was wondering if this has happened to anyone else... today I noticed that when I go above 3.5-4k RPM my Tachometer begins to jump around... like it doesn't go up smoothly but instead it looks like it sticks to something and jerks up or down... the engine runs normally.
I will be taking it apart this weekend. I also have a spare one... so I am not worried but still we both thought it is fairly weird and uncommon. -Sov
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd |
My guess would be the drive gear for the speed sensor is about to fall off its axle. What ever holds it in place is gone or loose and it grabs randomly.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Hmm... would have to check it... One is in the trans axle case, the other is in the torque converter case... which one should I prioritize? However, I think it is easier to remove and install a different cluster since I already have one spare... to make sure its just not the cluster itself...
Any other ideas though?
Yeah, the tach is controlled by the ECU. If there was an issue there, the car would run funky. I'd bet your problem is in the cluster itself.
Great, will check it out and report back.... perhaps will just install a new one and forget about it... planning on installing HIDs this weekend
My apologies, Trevor and Hocrest are correct. I should have read your post better, I thought you were refering to your speedometer.
It was easy to fall into this trap as the speedometer fault has so often been discussed. Not a problem, particularly as your thoughtful apology enhances the thread, makes the/my day and is sincerely appreciated. Cheers, Trevor.
