Where to get the coolant temp sensor
I've been trying to find the coolant temp sensor, but I haven't had much luck finding it online. Would someone be able to give me a link to it? I don't want to buy the wrong part.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Where to get the coolant temp sensor
Thanks! Does it matter which one I get? I think I'll just get the most expensive one. If it doesn't matter, then I'll get the cheap one
Get it from the dealer....
Yes, non-OEM temp sensors are not well calibrated! Too risky....
