Intermittent ABS Antilock Brake problem
I've got my ABS light on again, and as always, it's picking up as the front right sensor.
More than once, I've had the light come on after doing suspension or brake work on that corner of the car. What's odd to me is that, in doing the brakes, the tone wheel and sensor aren't moved, so I don't really feel that their spacing is suspect. It's possible that the wire is faulty, but I load and unload the suspension all year when changing tires for autocross or putting the snows on, and I don't think the light has come on following a tire change. Any bad guesses? I've got a new sensor, but I'd hate to put it on if I don't have to.
Disclaimer: The above post is on the internet. |
Re: Intermittent ABS Antilock Brake problem
You can get this problem if the front axle nut is loase or the bearing is shoot. Check to see if the wheel wobbles. The last thing to check is if the clearance form the tip of the sensor to the sender plate is right. Some times you need to adjust the shims between the sensor and the backing plate.
Front sensor clearance 0.7 to 1mm (0.028 to 0.039in) and for the record back one 0.5 to 1.0mm (0.020 to 0.039in). Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 05-17-2009 at 02:41 AM. |
Check the tone wheel if it has a crack in it. That was my problem when my ABS light came on. It happened right after my mechanic did some work on my suspension.
