Old 03-29-2003, 06:22 PM
JeffN JeffN is offline
Engine vibe after new radiator?
Why would I get an idling engine buzz felt throughout the car after simply having a radiator swap? It seems to abate when I turn the wheel at idle without moving thereby changing the rpms down under load. Weird.
Old 03-30-2003, 09:14 AM
I can't see any mechanical reason to link a Radiator to a vibration, unless some of the mounting bolts were left loose.
Old 03-30-2003, 09:19 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
A lot of cars use pin type mounts on the radiator, if I recall correctly this is the type found on the SVX (too lazy to go look right now.) If the pins aren't centered in the mounting rubbers you can pick up a vibration. Also check that the bottom of the radiator is sitting where it belongs, I've found a few that weren't properly installed. One more item to look at are the top and bottom rad hoses - make sure they aren't old and stiff and that they aren't pulling/pushing/twisting the radiator away from its intended position.
Old 03-30-2003, 10:16 AM
The hoses are new also, I think it's the rpms-somehow changed too high since it smoothes out when the PS pump is loaded by turning the wheel slightly and holding that position...
