Old 04-08-2003, 10:30 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Originally posted by mbtoloczko
200k miles on original plugs? Wow. I would think you could get some benefit to replacing the plugs after this many miles. Be careful when removing them. I'm wondering if they might be almost seized to the heads.
One reason why I am holding out is it is a major PITA to do it.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-09-2003, 05:25 PM
SVXPILOT SVXPILOT is offline
I possibly might have 240'000 on the originals. I want to change them but haven't wanted to risk it yet until the 89 silverado is back in service just in case I break something.
Old 04-11-2003, 09:01 AM
STORMINORMAN STORMINORMAN is offline
Cool Hmmmm. I didn't have THAT much...
...of a problem removing my plugs at 60K. If you remove the airbox and the battery & tray there seemed to me to be very little problem in accessing the plugs. Not compared to some other memorable jobs I can recall: the PCV on the SVX was an SOB, the belt tensioner on the 420SEL required that I fabricate a tool to loosen the bolt, water pump on a Fiesta required that I ground down the bolt heads to get a box wrench on them, etc.
Only problem I had was not having the PERFECT length extention, so I went crazy and bought another 1/4" drive metric Craftsman set at Sears for $10 (on sale as I recall).
Plugs and boots came off with no problem: anti-seize & dielectric grease help. I used the regular Bosch platinum plugs and they were $1.49 each. No gapping, BTW!
100K miles is way too long IMHO to leave any plug in an aluminum head
CHEERS!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 04-12-2003, 09:53 PM
SVXCAPE
maybe its just me
Although I am mechanically gifted it took me less than an hour to change them.
I removed the airbox, battery, and an ABS bracket I believe. Be very patient and don't get frustrated
The coil packs are a little tricky, but with a little manuvering are very doable.
