Old 02-27-2003, 05:39 PM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
Gas gauge is WAY off...
My gas gauge is getting really bad.. Last time I filled up, it was on E for almost 50 miles, and it only took 11.5 gallons! I heard there's a way to adjust it, but forget how.. Any ideas?
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 02-27-2003, 07:21 PM
subymtnguy's Avatar
subymtnguy subymtnguy is offline
"high" in Colorado
gas guage....
Mark,
When I got my car, the gas guage did not work. If I filled up the tank it would go up to about 3/4 for a few miles then fall to 1/4, then back up to almost a half, then to empty etc. etc. In other words, it read all over the map....
There are two floats (sending units) in the tank; one on each side. Access is with the seatback down under the carpet, under the rear deck. The problem turned out to be the float on the right (facing rear).
I bought a used one from one of the forum members, and all has been well since. It was one of those things that really was aggravating...
If you decide to check this out, run most of the fuel out of the tank, and remove the filler cap to relieve pressure before you open the tank access.
Hope this helps...
92 Liquid Silver LSL
85 BRAT GL
81 280ZX
91 Legacy wagon
86 Pontiac Parisenne (55k)
86 Kawasaki ZG 1000 Concours
81 KZ 1000 LTD (shaft)
Old 02-27-2003, 07:46 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Make the light show up. Pull the needle out and push it back in at E.
That's what I did to mine and works nicely.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-27-2003, 09:49 PM
JLittell
...and remember to not "light up" during this procedure Gotta be the float.
Old 02-28-2003, 09:53 AM
Zeppelin's Avatar
I'll give the needle trick a try first, since my gauge doesn't "bounce" all over the place.. After filling it up a few days ago, about 45 miles later I'm at 1/2 a tank already!
