Old 09-18-2005, 09:44 AM
Bill, I have pointed arrows showing that the washers go between the mounting bracket that you need to hack up and the top of the mount(the side with 2 studs) The washers go around the 2 studs and the mounts should bolt onto the bracket. It is fairly simple once u understand what needs to be ground down on the bracket. I really wish I remember to show you in person. Maybe next time. Thnx for all of the advice at ripken u helped me alot
Old 09-18-2005, 02:17 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by SVXRide
Tom,
Did Chike take one that was actually in focus?
I can't tell from the photo where the washers are....anyway you can work with Chike to annotate a picture to point out where the washers are?
Thanks.
Hey, good seeing you again at Ripken! Keep at the autocrossing, your times will come down!
-Bill
I wish Bill. It was too early and I was still waking up...
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-18-2005, 05:46 PM
Subafreak's Avatar
Superbeast
I dunno man, I didn't have to grind the sides of the mount at all to make them fit.
Old 09-18-2005, 06:06 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Jesse,
Does this mean you're willing to take some digital pics of your motor mounts?
(Please!)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-18-2005, 06:17 PM
Subafreak's Avatar
Superbeast
Jesse,
(Please!)
-Bill
I would be glad to if the freaking network would accept my pics.
Old 09-18-2005, 06:36 PM
SVXRide's Avatar
Jesse,
email them to me at wiiliam.e.cutlip@nasa.gov
I'll make sure they get posted
-Bill
Old 09-18-2005, 06:49 PM
Maybe I said it wrong. I ground down the sides of the mounting bracket not the mount
Old 09-18-2005, 06:51 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Jesse, I had used washers to shim up my old failing mounts before I bought a used set from Tom. Nothing wrong with that approach. Later I slid (pinched?) in a couple shock biscuits (from a Merc, go figure) alongside the center stud in the trans mount. It helped quite a bit with the driveline slop and actually also removed quite a bit of the jitteriness I've been associating with weak front struts. Also noted was the change in vibration at high speed. I've been chasing little vibrations in the car since I bought it, tires, wheels, etc. The p.o. had a new driveshaft installed just before I bought it so I had little reason to suspect it. Now I'm thinking that with the ridiculous angle of the engine/trans (to allow for the front diff and exhaust) a sagging trans mount only adds to the trans output inclination. It sucks that I'll have to pull the exhaust and shields to inspect and measure angles but I think I'm on the right track.
Considering how much torque deflection there is in the trans mount what do you think about adapting a Moog type dogbone replacement strut (like the Citation, etc. used) in place of the OE dogbone, once the driveline angle issue is resolved? It should certainly firm up the reaction both on and off power.
