factory reverse backup light wire color? for backup camera
hi i am looking for a reverse backup light on the factory wiring harness so i can wire up a back up camera? is there a wiring diagram that would tell me what wire to tap in too?
Re: factory reverse backup light wire color? for backup camera
From the FSM. The 12V power is the brown wire with the yellow stripe. The black wires are to ground. .
my aftermarket radio harness has a reverse gear signal wire.
So in order for the radio, to know that i was in reverse i will have to tap in to the brown/yellow wire run that wire to my aftermarket and attach it to the reverse gear signal wire? also is there a closer location of that wire from the radio? Last edited by kjoyes; 03-25-2012 at 08:32 PM. |
the switch on the side of trans is pretty easy to get to but i would just put a switch somewhere, a lot of backup cameras and head units take several seconds to switch on and to the different input which can be annoying when you are doing a multi point park job. if you have the switch you can turn it on whenever you want.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
