STi (group N) motor mounts installed
STi group N motor mounts have been installed. It was done as part of the 5MT upgrade that is in-progress and also for HP additions coming later on. Anyhow, the mounts are not a straight bolt-in mod. The STi mounts are about 1/4" shorter than the SVX mounts. My mechanic (oppositelock) ended up using the SVX mounting plate. He had to slot the holes in the plate and weld a 1/4" thick spacer plate to the mounting plate to make everything line up properly. I'll let oppositelock add the details. He's got pictures too. One of us will be adding them soon.
How about them pick?
I only dig this up becouse I found out I had a broken motor mount when I pulled my motor out, it probly happend during the devastating launch but if I tore it then I'm sure I'm gonna do it again. So where can I get these and what is a good price for them?
I'm looking for a reasonable alternative also. As far as I'm concerned Subaru can either make their price reasonable or pitch the stock in the dumpster. Good grief, hydraulic mounts for a 32valve Lincoln are around $48 @ NAPA.
<http://www.subaru-svx.net/photos/user.php?mbtoloczko|25050> The mounts are available from many places. Since you are near the East Coast, I'd recommend Rallispec at $86/pair (very good deal): http://www.rallispec.com/ If you don't already have the Group N tranny mount for your 6MT, you might want to get one of those too.
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
My only comparison would be with the 4eat and the stock engine mounts. Compared to that, there is a slight increase in vibration, but nothing even mildly annoying. No increase in noise. Can't compare shifting performance and driveline stiffness, but I can tell you that the Group N engine mounts have travel limiters that only allow about 1/4" total engine rock.
Hell that price don't sound bad! I'm assuming the STI mounts are just solid rubber instead of liquid filled? And that in return they are less breakable?
I already got the tranny mount, I belive they are a neccesity with a manual in the SVX.
i bought mine at subaruparts.com for $125 for both of them with shipping. Took about 4 days to arrive.And yeah they are solid rubber... I believe a lot better than stock. I also have the 5 speed trany. when my stock motormounts went bad. It destroyed my clutch cable and the fork. So I end up replacing tranny and clutch. I replace 3 time the clutch cable before it got to the tranny part. Once i replace all the tranny stuff i check on the mounts and that was the couse of all my pain. So check them!!!!!
Are you sure that your 6MT tranny mount is the Group N version? There is a standard STi 6MT tranny mount that looks similar but uses a softer rubber compound than the Group N 6MT tranny mount.
Well isn't that a good question? I'm not sure if it's the group N mount but it is a hell of alot stiffer than the rubberband stock one.
Are these the mounts I should be buying? I want to order them today if possible as to get them sooner
Ebay auction Tom |
If you want those STi mounts cheaper go to http://www.rallispec.com/
They are currently out of stock. |
I have the mounts bolted up to the brackets and ready to go in the car tomorrow. Jesse, did you put your's in yet or are you just wating for a good time? Anyway I will let you know how the install goes once I am finished...hey Bill, did ya finish yet??? BTW for anyone interested I may be going twin turbo... the turbos on my bro's car survived the fire Just a thought right now, I would probobly go RWD w/ the Z trans if I did go that route.
Tom |
Yeah , I put them in on the same night Tom. I kinda needed them.
So how exactly is yuor brother gonna make any money off this car?
