How long does my trans have?
so here is the rub,
I bought this 92 LSL a few months back it has 176k it was beat to **** mechanically and on the exterior by the PO the interior is in great shape however .. anyway, back to the matter at hand. The transmission has a shudder/vibration around 1900-2400k rpm it feels like in every gear, but in 3rd and 4th you really feel it. Also very occasionally the shift between 2-3 slips and i do get the very occasional bang going into reverse this mostly happens when going from drive to reverse like on a 3 point turn and yes i was fully stopped before the shift. I also get a strange surging when taking off when cold on a right turn at anything below 1/2 throttle. I'm not sure if its related or if my MAF just needs a good cleaning and or re-soldering The service records indicate that the trans was rebuilt about 50k ago. I still wanted to service the trans because the fluid looked dark. so when i dropped the pan this is what i found.. That magnet is looking pretty damn fuzzy and those chunks sitting next to it are pretty damn big... what i didn't snap a pic of was the bolt that was laying in the bottom of the pan as well, It was one of the bolts that go through the filter so i installed a new filter and filled her up with some max life and a bottle of lubeguard red it feels a little smoother but is still vibrating. I did remove the Subaru added external filter as it was leaking and rusty i figured it was probably running in bypass mode anyway. is there anything else i can do to prolong the life of this trans? is it worth adding a external cooler and filter? or should i just save money for a 4.44 swap? |
Re: How long does my trans have?
Do the 4.44 swap. I put a secondary trans in it and it went 2 years later. Some people get lucky and others don't. I should have done the 4.44 the first time instead of wasting my money on a used trans that has major issues to begin with.
A used trans is always a used one. Based on my personal experience, rebuild the 4.44 trans before you install it.
The bang you hear in reverse can be a worn drive shaft U-joint.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 11-11-2014 at 09:08 AM. |
