Old 03-28-2004, 09:13 PM
mbtoloczko's Avatar
sans SVX
STi (group N) motor mounts installed
STi group N motor mounts have been installed. It was done as part of the 5MT upgrade that is in-progress and also for HP additions coming later on. Anyhow, the mounts are not a straight bolt-in mod. The STi mounts are about 1/4" shorter than the SVX mounts. My mechanic (oppositelock) ended up using the SVX mounting plate. He had to slot the holes in the plate and weld a 1/4" thick spacer plate to the mounting plate to make everything line up properly. I'll let oppositelock add the details. He's got pictures too. One of us will be adding them soon.
Mychailo
Visit my locker
Old 04-26-2005, 08:39 PM
Subafreak's Avatar
Superbeast
How about them pick?
I only dig this up becouse I found out I had a broken motor mount when I pulled my motor out, it probly happend during the devastating launch but if I tore it then I'm sure I'm gonna do it again. So where can I get these and what is a good price for them?
Old 04-26-2005, 10:28 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I'm looking for a reasonable alternative also. As far as I'm concerned Subaru can either make their price reasonable or pitch the stock in the dumpster. Good grief, hydraulic mounts for a 32valve Lincoln are around $48 @ NAPA.
Old 04-26-2005, 10:52 PM
mbtoloczko's Avatar
sans SVX
Pics in my locker here:
<http://www.subaru-svx.net/photos/user.php?mbtoloczko|25050>
The mounts are available from many places. Since you are near the East Coast, I'd recommend Rallispec at $86/pair (very good deal):
http://www.rallispec.com/
If you don't already have the Group N tranny mount for your 6MT, you might want to get one of those too.
Mychailo
Visit my locker
Old 04-26-2005, 11:22 PM
GreenMarine's Avatar
From POST-***** to LURKER
Does it do anything noticable??? Vibration... Shifting ease.... Niose??? Any of those change over stock??
Old 04-27-2005, 07:30 AM
mbtoloczko's Avatar
sans SVX
My only comparison would be with the 4eat and the stock engine mounts. Compared to that, there is a slight increase in vibration, but nothing even mildly annoying. No increase in noise. Can't compare shifting performance and driveline stiffness, but I can tell you that the Group N engine mounts have travel limiters that only allow about 1/4" total engine rock.
Mychailo
Visit my locker
Old 04-28-2005, 04:41 PM
Subafreak's Avatar
Superbeast
Hell that price don't sound bad! I'm assuming the STI mounts are just solid rubber instead of liquid filled? And that in return they are less breakable?
I already got the tranny mount, I belive they are a neccesity with a manual in the SVX.
Old 04-28-2005, 04:56 PM
blacknite blacknite is offline
i bought mine at subaruparts.com for $125 for both of them with shipping. Took about 4 days to arrive.And yeah they are solid rubber... I believe a lot better than stock. I also have the 5 speed trany. when my stock motormounts went bad. It destroyed my clutch cable and the fork. So I end up replacing tranny and clutch. I replace 3 time the clutch cable before it got to the tranny part. Once i replace all the tranny stuff i check on the mounts and that was the couse of all my pain. So check them!!!!!
Old 04-28-2005, 06:14 PM
mbtoloczko's Avatar
sans SVX
Yeah, you will not break them. Because of the travel limiters build into Group N engine mounts (look at pic #3 in my locker), there is no way for the mount to stretch more than about 1/4". After that, it hits a rubber coated metal stop.
Are you sure that your 6MT tranny mount is the Group N version? There is a standard STi 6MT tranny mount that looks similar but uses a softer rubber compound than the Group N 6MT tranny mount.
Mychailo
Visit my locker
Old 04-28-2005, 06:23 PM
Subafreak's Avatar
Superbeast
Well isn't that a good question? I'm not sure if it's the group N mount but it is a hell of alot stiffer than the rubberband stock one.
Old 04-29-2005, 03:48 PM
Beav's Avatar
Not as old as Randy
The stock SVX mounts also have travel limiters built into the brackets, as you describe.
Old 04-29-2005, 05:33 PM
mbtoloczko's Avatar
sans SVX
My recollection is that the OEM SVX engine mounts only have compressive travel limiters. Is this incorrect?
Mychailo
Visit my locker
Old 04-30-2005, 12:37 AM
Beav's Avatar
Not as old as Randy
Incorrect. The tabs sit inside pockets.
Old 05-13-2005, 09:08 PM
longassname's Avatar
Just some dude.
does anybody have oem motor mounts laying around. I've blown mine and want to order the group n motor mounts. I'm hoping I can get my hands on a borrowed or diverted to me before the trash can set of svx mounts so I can fabricate the adaptor plates before pulling the remains of my mounter mounts out of the car.
Old 05-13-2005, 09:25 PM
Subafreak's Avatar
Superbeast
Well I already told Dave he could have mine, sorry
At least your still gonna get the intake
