OEM struts. Options?
I hope this is in the right section.
I recently got me a SVX. Really clean in appearance, but leaking a little oil and no service history. 150 k miles decided to take care of the leaks and replace the timing belt. Needed rear brakes too. One item I was not expecting because the inspection before i bought the car did not identify it was a blown out strut. I like the stock ride, I am wanting a comfortable commuting car, so I was thinking OEM struts. Now I read that there may be issues with OEM because they have been on a shelf too long. They have a 12 month guarantee. I don't really know of any other option tho. Right. Is there one? There is a thread about some custom struts being made at $1400 a set. What are my odds of early failure with oem struts? Thanks for any input. Last edited by SUPER; 10-09-2012 at 07:11 AM. Reason: set, not pair. Fixed my mistake |
Re: OEM struts. Options?
If you're not interested in any sort of performance setup the only sensible choice is to buy Subaru struts (and take your chances). I've had "new" struts on one of mine for awhile with no issues. Of course, one could fail tomorrow. It's a 21 year old car. Anything could fail tomorrow.
dcb |
If you're going to just get a couple of struts and nothing else, then the best viable option is to get the OEM struts from subaru. Before I decided on getting the AMR struts I read every post I could find on them and only found 1 instance where someone said they failed and it was within 3-4 months of getting them. If you have a 12 month warranty I'm sure you'll be fine.
However, I didn't just want to buy struts but also wanted to get new springs, bushings ect. I called subaru and for all 4 struts, springs, strut mounts, etc it was going to be around $1600. That being said I decided to go with the AMR ones because the cost would be about the same for what I was doing and these have a lifetime warranty. I thought this might be a better option for the long term.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Keep in mind them OEM strut warranty only covers the parts.
You will have to pay the labor to remove and install them again if they fail. The struts themselves are only $126, its the labor that drive it to that $1600 quote.. |
Granted, that was a while back (7-8 years or so), but when I placed the order for the AMR ones, I asked him how much it would be and he said he could still do it for about $40/strut.
Keith |
Also there is evidence in this thread that a more recent run of OEM struts was made: http://www.subaru-svx.net/forum/show...t=60263&page=2
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
In response to halistan... There have been tons of cases of "new" OEM struts failing. Just because they aren't all documented and posted in one place or many aren't documented at all, doesn't mean that it's only been one case... This isn't a myth, and it has been going on for many, many years. You are much better buying used OEM struts for 1/3 the price of new OEM as the used will likely outlast the OEM anyway... |
another option you have is koni inserts that option may not be lasting too much longer but for right quality and it pretty long lasting strut that would be perfect
Meanwhile, back in the real world, no documented instances of failure = myth
Whaaaaaa, whaaaa poor benebob :-( We cant help you're unlucky but one person getting a bad strut isn't an indicator that they are all bad.
Do yourself a favor and don't buy a lottery ticket.
Why don't you go ask Tim Eng about the 3 sets that failed before warranty was out and he ultimately went with konis....
Do yourself a favor and buy yourself some struts that make great turd holders....at least when you shove them up your a$$.
