excessive toe wear on front tires
My svx is a fwd car and I see a lot of toe wear(inside part of wheels)
I also had someone tell me that it is normal for some cars to do that all the time and its not fixable, so I thought I would ask the most reliable people I know is it true for the fwd models or is he just blowing smoke? |
Re: excessive toe wear on front tires
Toe and camber is adjustible on the SVX stock. An alignment shop should be able to get you a proper setting for good tire wear with whatever driving style you have.
I had it aligined once (les shawb)and brand new tires on the car at one point and saw the same problem.... why would it revert back?
worn bushings, poor alignment, damaged tie rods, etc.
My guess is the alignment tech was lazy and sloppy and either didn't see or ignored any problems. If there is no problems it still could have been a bad alignment job that was still "in factory specs". |
Stock wheels and tire size? Any mods or damage to suspension prior to your ownership? Tires rotated regularly? Just sayin'.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Don't discount the fact that some tires are just a poor design or a poor match for the svx suspension.
On my svx, which I have never taken back to an alignment shop as I went through these tires; I've never had a set of yokohamas that didn't wear out the inside shoulder to the belts well before the summit made the wear bars even get close. 3 sets of crap. Yokohama - never again. Went through 3 sets of Falken Azenis sports with perfectly even wear. 2 sets of michelins have worn fairly evenly.
