Head bolt nuts
Probably asked a million times, but I finally got a friend to bring a 250 ft lbs impact for my cam gears, that wouldn't break it lose. Called yet ANOTHER friend with 500 lbs one, got it of and pull the cams out, thinking I was about to finally pull one of the heads off but I can't get the head bolts off. Looks to be more than a 12 point bolt, we didn't have a impact socket that would fit but we gently tried to use a normal socket and that wouldn't break it lose. What should I be using to remove these last few bolts?
Re: Head bolt nuts
The bolts have 14mm 12pt heads on them. The block bolts are 12mm 12 heads-/ -/ Tom |
Re: Head bolt nuts
I haven't pulled them off yet so I'm not sure what they are but I was assuming the actual bolts are in the block and the head drops on to them. Guess I just need a breaker bar.
Re: Head bolt nuts
Tom |
Re: Head bolt nuts
I wouldn't for putting them back on but I was told taking them off shouldn't be a big deal since the bolts needs to be replaced anyway. Anything else I should know?
Re: Head bolt nuts
Tom |
