How To: Clean and Restore Headlights and Grill
This is a quick How To writeup for your headlights and for the waterfall grill.
First: If you need to open the head light for any reason (i.e. remove broken glass from broken bulb) 1 - Remove headlight assembly from car 2 - Remove clips holding the front and back of the headlight together 3 - Pre-Heat your oven to 220 degrees F. 4 - Place headlight assembly on a cookie sheet and place in oven for 20 minutes 5 - Remove CAREFULLY. It will be hot. 6 - Gently pull the front and back of the headlight apart. This will take a good amount of force, just be slow and gentle so you don't break anything. That glue doesn't like to give. 7 - Do your cleaning. IMPORTANT: Use ONLY a microfiber cloth and cleaner WITHOUT Amonia on the reflectors. Mild hand soap and water works the best and is generally safe. (that's the same thing we use to clean professional lighting instruments) 8 - Place the two halves back in the oven for 20 minutes 9 - Remove CAREFULLY. Using oven mitts or something take both halves and press them back together fully 10 - Re-Install the clips holding the light together. In this picture you can see the clips that hold the light together. One near each side. They're the little metal pieces. Second: To clean yellowed, foggy, or pitted lenses (This works for the waterfall grill as well) If your headlights look hazy or yellow or pitted like this: To start you will need a few items.
1 - Get some kind of container and fill it up with water. 2 - Start with the 600 Grit sandpaper. Make sure you keep everything wet! Sand down until the water stops turning yellow, or until the surface is how you want it. The lens will be very hazy at this point. I start going one way (side to side), then after I'm done I switch to the other way (top to bottom) 3 - Move on to the 1000 Grit sandpaper. Same procedure as with the 600 4 - Now move on to the 1500 Grit Sandpaper. Clean the lens up as smooth as you can get it. 5 - Clean the lens off. It will be somewhat hazy at this point, but there should be no major scratches, just very very fine scratches that make it look hazy. 6 - Apply some of the plastic polish (PlastX from here out) to a rag and begin polishing the lens. 7 - To make this easier, if you have an orbital buffer, use a terrycloth cover and apply the PlastX. 8 - Keep a generous supply of PlastX on the terrycloth cover/lens and polish as long as you like. I've found it helps to clean the old stuff off once in a while and re-apply 9 - I usually do this for five to ten minutes 10 - Using some kind of glass cleaner and a microfiber cloth (doesn't have to be microfiber, but I prefer them) clean the lens. You should be left with a result similar to this: (this is the same light from above) And this is the other side that I forgot to take a before picture of: Here is a picture of a grill after the same process. It looked similar to the before picture of the light. As for the rest of the light, Paper towel, a toothbrush, and Simple Green cleaner were all that I used. Patience and care are all that are needed to clean the rest of the assembly. Before Cleaning
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) Last edited by techy101; 03-27-2009 at 02:55 AM. |
Re: How To: Clean and Restore Headlights and Grill
A few After pictures:
Now it's time to put your beautiful new headlights back on the car
ALICE: 2005 Forester XT (Ice Racing Machine) River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment) |
Just a word of caution when using the orbital buffer.
Use a low speed and dont use alot of pressure. If you get it too hot, it will burn the plastic.
Prime Сasual Dating |
Mine is just a cheap consumer grade electric orbital from WalMart. It doesn't go fast
Keith |
I think i missed the step for spraying with UV blocking clearcoat.
If you don't use the UV clearcoat, your buff job only will last about 6 months tops.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Great information!
thank you! Keith |
Mother's Mag and Alluminum polish works great and is fairly trouble free. Mine have stayed crystal clear for at least a year. It might be easier than the above method.
This will address larger and deeper issues like scratches and pitting. And no one is saying you have to do it, I just wanted to share something that has worked for me. To try and give back to the forum.
So you don't need to use any new sealant when reassembling the headlights?
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
they should be fine with reheating them because the epoxy stays in place.
Whats the reason you take it apart? The inside should be fairly clean already, no?
__________________ |
