Old 01-09-2009, 02:24 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
My possessed car - video
srsly, wtf. I just replaced the alternator and battery, dremeled the ground points, continuity is good between battery and chassis, and it's still doing this ****. After it warms up and the rpm's drop it will slowly bog down and die at idle.
No smoke, fluids, or funny noises coming from the engine. I'm selling it tonight to a buddy driving down from Massachusetts and need to know if this could possibly be a quick fix, or something worse. I want to sell it for an honest price so if it's an exploded engine, fine he can take it cheap. Just want to find out what's wrong.
Brian
Old 01-09-2009, 02:35 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: My possessed car - video
Oops ok the vid just loaded..... I rescind my last post lol. Given that it seems random enough and it does it more while the car is vibrating/revving, could be a loose harness or wire? Electrical issues are such a pain in the a$$!!
Old 01-09-2009, 02:39 PM
Wikedjuggalo's Avatar
Rebuilding
Its gotta some related to battery/alternator. How are the connections going to the alternator?
Old 01-09-2009, 02:46 PM
Ricochet's Avatar
I brought some ham.
I checked everything with an ohm meter, all wires are connected fine. This new alternator came out of a perfectly-running svx.
Brian
Old 01-09-2009, 02:59 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
What happens if you measure the volts across the battery when you rev like that? If that's not a charging system or ground problem, I'll be surprised.
Old 01-09-2009, 03:18 PM
Manarius's Avatar
Manarius Manarius is offline
With that kind of lighting, I'd almost be inclined to think it had to do with the regulator in the alternator - wavering output with engine speed, regulator could be broken.
-Jason
-Obi Wan Kenobi
Old 01-09-2009, 03:38 PM
bheinen74 bheinen74 is offline
get a mm tester and check the battery voltage. maybe the battery is no good, maybe the alternator is not producing 13.8 volts or higher.
its one or the other, or a bad battery connection.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 01-09-2009, 07:02 PM
dennyo dennyo is offline
please post when you find the source and the solution.
Old 01-09-2009, 07:23 PM
sicksubie's Avatar
What is the alternator putting out???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-09-2009, 08:21 PM
kwren's Avatar
kwren kwren is offline
if the battery is charged up and functioning properly it will run for 30 miles without an alternator.
No lights or accessory on of course.
Old 01-09-2009, 09:16 PM
sicksubie's Avatar
my friend and I need to go slightly more than 30 miles to get this car though...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-09-2009, 10:37 PM
Check the ground on the backside of the manidol passenger side. There should be a 12mm hex head holding it on. Make sure it is a good connection and that it is tight
Old 01-09-2009, 10:41 PM
kwren's Avatar
The point actually was that the problem could not be a natural battery or alternator problem. I was suggesting to look elsewhere for the problem. Everyone was dwelling on the alternator and battery, and if a car can run 30 miles without an alternator, it wouldn't just drop down to nothing because the rpm is brought down to a normal idle.
Quote from Ricochet:
Sense that doesn't even happen when the battery or alternator is bad, I would suggest maybe looking for a problem other than the alternator and the battery if you have tested them already.
Keith
Old 01-09-2009, 10:46 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Took a glance at the fsm and it says to check or replace fan belt, check alternator, check terminals for improper contact if the charge light is on at idle which his is slightly.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-09-2009, 11:46 PM
Ricochet's Avatar
I brought some ham.
Pardon my ignorance, where is the fan belt?
Brian
