Old 02-22-2003, 11:30 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Originally posted by Aredubjay
Because you're probably like me, looking for these "LARGE" , gaping mammoth hole things. the rubber plugs are about the size of a quarter and they're usually covered with muck or gunk from the internal or external surfaces. They're there. You just have to look closely. Look for the closest to the driver's firewall coil, then, run your hand along the fender wall just in front of it. You'll feel the rubber plug.
Randy, i could have a field day with this post!!! but ill keep my mind out of the gutter
phil
~Phil
Old 02-22-2003, 11:51 PM
Green1995SVX
phil
HAHA OHHH GOD!
http://www.subaru-svx.net/photos/fil...95SVX/6099.JPG
You can see the plug pretty well in that pic.
Mike
Old 02-23-2003, 02:36 PM
The Molinator
Talking knuckle sandwich!
Beav is right! Unfortunately it is simple (used 12 mm LONG closed end wrench for coil bolt) - BUT I still mutilated my knuckles working in such a tight space. I guess I'm not as nimble as I thought!! (I'd say, if you have big hands, sub it out!, otherwise it takes about an hour for us wannabees.)
Good Luck
Jim
