Old 02-13-2003, 08:41 PM
AFBeefcake's Avatar
Subaru Swapper
rear brake rotors ?
which years have soild rear rotors and which years have vented rear rotors.
also did some years have 2 POT calipers in the rear?
2005 Legacy GT
My WRX's Cardomain Page
Old 02-13-2003, 08:47 PM
Green1995SVX
All years have solid rear rotors.
All years have single piston calipers.
Mike
Old 02-13-2003, 09:07 PM
AFBeefcake's Avatar
Subaru Swapper
then i guest this sit is not right
http://www.pureperf.com/brakes/Subaru_crossdr.html
they list rotors for svx 92-97 AWD w/ vented rear discs
and the 94-95 FWD (usa only) w/ plain rear discs
i have the plain rear discs from this company and they fix fine on my 1994 AWD
they must not know or its a type o
2005 Legacy GT
Old 02-15-2003, 02:14 PM
Different rear brakes!!!
They are also shown in the Shop Manual, Vented or plain.
Old 02-15-2003, 02:36 PM
Green1995SVX
Ok then, does anyone here have vented rear discs? My 95 AWD has solid.
Mike
Old 02-15-2003, 06:24 PM
AFBeefcake's Avatar
Subaru Swapper
I looked in my repair manual and it shows 2 POT calipers, and vented rotors
I was thinking that if there are svx's with 2 POT calipers, and vented rotors in the rear they could be used as an upgrade.
2005 Legacy GT
Old 02-15-2003, 06:36 PM
Green1995SVX
There simply isnt such a thing.
Old 02-15-2003, 08:00 PM
Subafreak's Avatar
Superbeast
What repair manual are you looking at?
Technially the SVX uses the same rear caliper as the Legacy's and Impressa's and there is a direct 2pot replacement for thoes.
Old 02-16-2003, 12:34 PM
alltrac alltrac is offline
do the front's have twin piston calipers
Old 02-16-2003, 01:06 PM
Green1995SVX
yes, they do.
Mike
Old 02-16-2003, 10:15 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
My original Rotors are coming off my '92 SVX Touring Edition this week, so I'll let you know if they are vented or not.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 02-17-2003, 03:25 AM
The Molinator
Smile REAR rotors
Mine were plain. I got replacements at Autozone for $70. a year ago. Still working fine! [Originally thot fronts were warped. Bot ventillated cross-drilled front rotors from Motorsports.com @ $400. per pair (quality "low" - had to drill two holes myself that they FORGOT! so I wouldn't have to return and wait for replacement). But, they still work OK.
Because of this, I'd like a ventillated upgrade myself!! Someone told me that the rear rotors may have failed first (odd) since the ABS was putting too much braking to the rear (?). Never checked it out.
Let me know, if the upgrade IS available. THANKS,
Jim
Old 02-17-2003, 08:33 AM
BLKSVX92's Avatar
BLKSVX92 BLKSVX92 is offline
Casper Killer
Send a message via AIM to BLKSVX92 Send a message via Yahoo to BLKSVX92
When i ordered my KVR x-drilled, the rears came vented, but when i pulled the rotors off the car they were solid. The caliper wouldnt even fit over the vented discs, i called the company that i ordered from, and took care of business.
Michael
1992 SVX Build 4/91 SOLD TO gsodonis
2002 Civic Si SOLD
2005 Lancer Evolution VIII TRADED
2008 STi
Old 02-17-2003, 09:20 AM
kuoh kuoh is offline
Re: REAR rotors
It sounds more like a front/rear bias adjustment, pad, or stuck caliper issue to me rather than the ABS. When my front calipers were binding, I noticed that the rear pads were worn much more than the fronts.
KuoH
