Old 02-09-2003, 06:14 PM
The Molinator
Headlamp BULBS???
What's the best replacement bulb for our headlights?
I've seen about 5 different types: standard, blue, high intensity, silver, superbright, etc.
THANKS!
Jim
Old 02-09-2003, 06:19 PM
lee lee is offline
best is a bit relative isn't it? I have heard that the Sylvania Silverstar is the brightest legal bulb sold in the US. In the UK I think there's a Phillip's bulb sold that's rated higher. Most of the Blue/white bulbs actually produce less usable light (those frequencies your eye responds to in night driving situations).
Old 02-09-2003, 06:30 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
I just put a set of the Silverstars in my Legacy. I highly recommend them. I bought them at AutoZone. They were only $15.00 each after a $5.00 rebate.
Old 02-10-2003, 09:51 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
I've used the Sylvania "cool blues" in my car for some time. I'll have to say that I wasn't impressed. Although, I can certainly tell a difference in driving the "Evil Twin" with stock bulbs, and driving "Patience" with the "cool blues." The "blues" do illulminate better. I will, however, upon nub's recommendation check out the Silverstars. I trust his judgement implicitly.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-10-2003, 10:08 AM
kuoh kuoh is offline
My friend recently upgraded the stock lights on his 2003 Ford Escape to Silverstars and said it was a waste of money. It did not look whiter or brighter than his stock bulbs. I've got the Cool Blues in mine and there was a noticeable difference between my 10 year old stocks and them, but it was most likely due to the age difference of the bulbs. If I were to upgrade the headlights again, I'd go with APC Plasma Superwhites 80W/100W and upgrade the headlight wiring harnesses. I helped the same guy install these on this Corvette and they are noticeably brighter and whiter.
KuoH
Old 02-10-2003, 11:10 AM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
I've been running Silverstars (low/high) for about a year now. I've already had to replace one (I think I may have moisture in my headlights ) but the light is fantastic. (It's too easy Randy - spare us - )
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 02-10-2003, 11:16 AM
Aredubjay's Avatar
<drumming fingers on table. Waiting for someone else to do it.>
Randy Johnson
Old 02-10-2003, 11:32 AM
wasions's Avatar
This must be agony for you.
Steve
Old 02-10-2003, 11:39 AM
Aredubjay's Avatar
A real trip.
Randy Johnson
Old 02-10-2003, 12:00 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
I've also heard great things about the silverstars. If I didn't have HIDs in the low-beams I'd put the silver stars in there.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 02-10-2003, 01:08 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
I replaced my cool blues with silverstars. The silverstars look whiter than the cool blues, which look whiter than stock. Both the cool blues and silverstars are rated at 1000 lumens (which, if I'm not mistaken, is the important factor in visibility). I didn't really notice an improvement in visibility with the silverstars, but I do like the color better.
Old 02-10-2003, 01:45 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Do the silverstars install without the need for an upgraded wiring harness?
I've noticed my stock lights are really yellow during the day, so I guess I'll check out the silverstars.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-10-2003, 02:35 PM
OK Randy - here ya go! I installed the silver stares (low beam) to see how they were. I was very impressed. Any others that I tried (cool blue etc)seemed to be a waste of time and money. The silver stars worked so good, that I bought another set for the high beams and I will try them out in the next day or so. I will let you know what I think of them.
Old 02-10-2003, 02:43 PM
Aredubjay's Avatar
Great, Earl. Thank you. Let's just hope this experiment doesn't go the way of your "super bright back-up bulbs" at Lafayette.
(Teach you to give me crap about my O-ring install. )
Randy Johnson
Old 02-10-2003, 03:05 PM
nubs's Avatar
Multiple Suby Owner
Why thanks Randy.That really means alot to me.
I have Wagner Lazer blues in my SVX,I have not driven it at night since I installed the Silverstars, but they seem to be much brighter and better color than the Wagners. And much better than the ten year old stock bulbs.
